Question about Fuji FinePix J10 Digital Camera
My FinePix J10 is not working even after changing the battery
I bought my Camera less than one year ago from walmart. My son inserted the battery wrongly after charging. After correcting, it failed to work. I bought a new battery but still coud'nt work. Please advise.
Your son probly jamed it in there to hard then the spring mybe broke
Posted on Feb 08, 2009
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My fujifilm J10 will not turn on with a fully charged battery and my battery will not turn on any other fujifilm j10.
Hi, It sounds like your battery can't hold a charge anymore. My suggestion would be to get a new battery for the camera and then it should work fine.
May 12, 2011 | Fuji FinePix J10 Digital Camera
FinePix J10 Digital Camera: I have just bought a fujifilm J30 camera. I have i...
Did you put in the battery the right way? If yes, try cleaning the contact points on the battery.
May 17, 2010 | Fuji FinePix J10 Digital Camera
Fuji FinePix j10 camera powers on but screen says lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 11, 2010 | Fuji FinePix J10 Digital Camera
I just buy a fuji finepix j10 2 month ago ,last weekend the lcd screen was broken ,where can i replace it?thank you
thank you for the e-mail, I had solve the problem because I decided to buy another new camera
Oct 24, 2009 | Fuji FinePix J10 Digital Camera
Flash does not work
Get your copy of the receipt and send it to Fuji. You will probably have to pay the shipping bill yourself. The warranty should take care of any repair charges, unless the camera has been physically damaged. You might also check with Best Buy to get them to ship it for you at no charge, as that was where it was purchased.
Jun 02, 2009 | Fuji FinePix J10 Digital Camera
Lcd will not turn on
check on the manual, there might me a button to turn lcd screen on, there is an option to keep it off to save battery
May 26, 2009 | Fuji FinePix J10 Digital Camera
Flash shuts two time and people close eyes
Change your flash mode from slow synchro to something else, sometimes the redeye mode does this to eliminate red eye by dialating the eyes on the first flash and capturing on the second. Check this link, go to page 48-49 and learn about the different flash settings of your camera.
http://www.fujifilmusa.com/shared/bin/J10_E.pdf
Mar 04, 2009 | Fuji FinePix J10 Digital Camera
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
Fuji finepix s3000
This is an easy possibility, Try using an eraser on all the contacts for the batteries. The ones on the battery door and the ones inside the camera. Try to get them shiny, the harder white erasers work best. If that doesn't solve to power problem, the camera may have blown its power fuse internally. That repair would likely cost 50-60$
Jan 08, 2008 | Fuji FinePix S3000 Digital Camera
Fuji FinePix J10 Digital Camera Logo
200 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
