Question about Reddy Heater-30-55,000 BTU Variable
Blower motor works but heater will not ignite
My reddy
  • rvitale Jan 31, 2009
    I took the reddy heater apart and cleaned it. Then replaced the spark plug. And it seemed to take care of the problem.
    Also for anyone out there looking for a manual, I went to
    www.desatech.com
    R.Vitale
    Problem Solver:
  • 12 Answers
Does this unit have hsi tech? i think so and if so the photo eye must see the glow from the igniter be for fuel discharge, otherwise the heater would fill the aera with and explosive mixture, try to cotton swalve the photo eye making sure of no obstructions first, i seen a mudd dopper make a nest in one before.
Posted on Jan 30, 2009
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
How many veins should the pump rotor have i took it apart and it only had two.but it has 4 slots
I take it you are talking about the air blower rotor?
YES--(Normally) It should have all four slots filled with sliding vanes.
Question are you getting enough air for combustion?
Does the blower motor have any trouble turning the rotor with only 2 veins in it?
I would think the blower would be leaking alot thru the empty slots, too
Do you need a source for the Parts?
This might help:
Reddy Heater - Troubleshooting Torpedo Heaters
Let me know if you need morehelp--
Mack B
Jan 25, 2011 | Reddy R115DT Oil Filled Utility Heater
Will the fan on the reddy heater not run if the ignighter is bad? When i plug it in the fan doesn't run.Do i need to replace the motor?
The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Starts to run. Then pops CB in about 2 seconds. Ignition is OK. I think it momentarily lights off. REDDY HEATER made by DESA of Bowling Green, KY
Hi, when a circuit trips that quik, it indicates a dead short somewhere or even a motor drawing way to much amps for the breaker to handle. If this heater is a forced air type, try and find the wiring that controls the blower motor and disconnect it for just a few minutes to test it. You may want to do this with other control componants one at a time, just by- pass each one by unplugging or disconnecting each one and start it. If the breaker holds when you do this, you will then know which part is causing the breaker to trip. Keep me posted on your progress.
Shastalaker7
Jan 18, 2010 | Reddy R155D Utility Heater
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
100,000 redi heater wont fire just blower fan runs
The igniter is most likely bad.Make sure the igniter is not working,and the pump for the fuel is working,one,or the other is not working,if it is the fuel,order a new pump kit,with impelar,and if it is the igniter,replace it with a new one.
Oct 21, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Will not ignite, checked fuse,fuel ok
these units will not ignite unless they know the blower is running. check for some sort of blower proving sensor.
Aug 03, 2009 | Reddy R60A Utility Heater
Reddy Heater-30-55,000 BTU Variable Logo
139 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
