Question about Acer Aspire 5100 Notebook
How do I replace the DC Jack on an Acer 3002lci?
I love the laptop BUT its not worth spending the $125 - $150 that people charge to do the work. I am willing to sacrifice the laptop if I screw it up in the process of trying to fix the jack.
  • Dennis H May 11, 2010
    Well for one thing , your laptop is more than worth the 125.00 for the repair, but I can repair it for you.
    You can e-mail me at: dennis@nwcomputersinc.com, I do laptop jacks , and for yours I'll do it for 99.00 help you out. Trust me when I say , if your not experienced in laptop repairs, you need to have the right soldering equipment( removal and repair) , as well as getting the correct jack, taking a laptop down to the motherboard, and putting back together correctly isn't for a beginner. aprox time involved is 3-4 hours.
    Also, are you sure its the jack thats the problem ?
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
Jun 02, 2014 | Acer Aspire 5315 Notebook
How do replace the DC jack on a samsung NP300V5A laptop
DC Power Jacks for the most part are soldered onto the motherboard. There are some models where the DC Power Jack and the cable harness just sits in a slot on the motherboard. And there are some models where the DC Power Jack is soldered on a little circuit board that is secured by screws to hold it into place. In any case to get to the Internal DC Power Jack you have to disassemble the laptop. And if it's soldered onto the motherboard, you will spend time unsoldering the old broken Jack before you can install the new one. Get a quote from a local repair shop, then check the guys out at: http://www.generalsystemsconsulting.com They will repair it and ship it back to you via Fedex or UPS cheaper than most quotes you get including the shipping charge.
Mar 16, 2012 | Samsung Computers & Internet
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
No power! power cord is good, but when inserted in the charging jack(laptop) the inside is loose and no charge is being sent to the battery. How do I replace the inside thing so power can be sent to the...
Here below is a guide about how to repair laptop DC jack, may it will help.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Jan 20, 2011 | Balance Computers & Internet
Dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Jan 11, 2010 | Dell Inspiron 1525 Notebook
Acer 5920-6864 ac plug only works when pulled to 1 side
Either the center pin on the dc plug or the small tension band inside the DC jack is loosing its spring, this spring action is what holds tension on the shaft of the pluug. The center pin that conducts the positive charge tends to break its solder point and therfore the chrge unless it is manipulated, the jack at this point needs to be replaced.
Sep 27, 2009 | Acer Computers & Internet
Acer 7520 charging problem
Try another battery in the laptop to make sure the battery isn't bad. If you do that and the battery still doesn't charge then go ahead and try a different ac adapter.
If neither of these two steps solve it then it could be that the solder points underneath the DC Jack have hairline cracks in them. If this is the case then you'll have to get the motherboard out of the laptop and then with a soldering machine and some solder, you'll have to resolder all the solder points of the DC Jack to solve the problem.
That should take care of the problem but if it still doesn't charge then the motherboard is bad and would need to be replaced.
Aug 11, 2009 | Acer (ACERMOTHERBOARD)
Basically it is just a matter of desoldering the old one, using a desoldering iron with a pump to remove the excess solder the resoldering the new one. Since you're willing to sacrifice, it can't hurt just be careful how much heat you apply because with multi layer boards you can easily screw something up by applying to much heat or solder. Good luck and please take a moment to rate as fixya.
Jan 30, 2009 | Acer Aspire 3002LCi Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
