Question about Infinity BASSLINK Car Subwoofer
Burnt amp had the sub playing and left car for min came back and no long playing checked all connections and still nothing...opened box and found that amp has a very small area burnt in the corner of the board between the battery looking thing and the wall...plz help me out Mike
  • controlthepr Apr 07, 2009
    Same here. Looks liKe we have to replace the little black burnt out thing. On mine I pulled it off and the bottom Was burnt toheck. You Know What those are called?
    Problem Solver:
  • 5 Answers
Inorder for it to blow out either there are two wires touching or it isn't properly grounded or it is faulty. if it is faulty you need to use the warranty(if it isn't too late) and get an new one
Posted on Jan 30, 2009
Hi i have a bnps102 subwoofer system along with a pyle 1400 watt amp. my amp is getting power to it hence the green light lighting up and the subs sounded great but last week during a song they both...
You are right about the scratching sound meaning the speaker is blown. The other one by it not playing it could mean the voice coils in it are blown or burnt.The safest way to check the speaker is to connect it to a standard 9 volt battery and listen for a popping noise when you make the connection and look the see if the cone stands up as long as the connection is made n returns to normal and no noises when disconnected from the 9 volt battery. To test this while the sub is plugged in to the amp but out of the box move the cone as far in and as far out as it will go. If it comes on while u hold it on either one of these positions but when released it goes back to not playing then the coils in it are blown or burnt and is no longer any good. As for selling the box its on you, aim anywhere from 2/3 to 1/2 the price you paid for it minus the speakers.
Aug 22, 2011 | Pyramid Subwoofer Box Dual 10" 1000w ...
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
Have SONY Xplod 1000watt dual ch. amplifier pushing two 12" MTX Terminators. About a week ago my my Sub on the right side quit working, while the left side sub is still banging hard as ever. I...
Check your subwoofer for resistance. It is more likely you blew a sub than a channel on the amplifier. If your subwoofer has no resistance, which can be checked using a multi-meter, then it is blown.
Jan 17, 2011 | Sony Xplod XM-1652Z Car Audio Amplifier
Everything is hooked up fine. the amp has power but no sound. I opened the amp and nothing looks burnt out.
Try you sub(s) on another amp...if they play off of it then its either your speaker outputs off of the amp or your rcas or wire from your radio are bad.
Nov 15, 2010 | JVC KS-AR7501D Car Amp
A3000DB Car Audio Amplifier: I hooked it up.It played for ten mins. Now no soun...
no, check your speaker wire inside sub box check your ground wire and you might need to wire your subs in series
May 17, 2010 | Power Acoustik A3000DB Car Audio Amplifier
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Subs just quit
It's probably not a battery problem; sounds more like a sub or amp problem. Check the sub's cone and see if it siezed up or if you smell something burned, also check the amp to see if you can smell the "burnt" smell. It's unlikely that it's your battery, because if it were nothing would be working properly. Take you subs and amp(s) to a good shop and ask them to bench test each item.
Jun 13, 2008 | Car Audio & Video
DHD ntx6408 subs
Voice coil has been blown open. Most likely alot of times what I do to test a speaker is connect it to a 9 volt battery. on and off and the speaker should bounce. If not speaker is blown. Plus this way you could save yourself lots of problems. If the speaker was shorted and not blown open. You would now possible have a blown amp and home stereo.
Jan 06, 2007 | DHD NTX-6612 Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
336 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
