Question about Fellowes DM8C Cross-Cut Shredder
Fellowes DM8C shredder
Materials aren't shredded, merely perforated by the blades. Did I overload it, or did it wear out all at once? Can the blades be sharpened? Can you adjust the alignment, are they just not close enough together any more? What can I do?
  • Anonymous Jul 20, 2008
    same problems how to fix
  • 328 Answers
What does the owners manusl tell you that the page limit is? Do not exceed it, and maybe just reduce it by one page at a time until you get the proper shred. Can not be sharpened. It would be cheaper to buy a new shredder.
Posted on Jul 31, 2007
Why paper won't feed when shredder turns?
This may seem to simple but.......sometimes when you put too much oil into the blades through the top portion, the paper get drenched with oil and will not feed in. Plz try a few sheets or a thicker paper to push through. It may just be that simple. Good luck.
Plz N' Thnx, Bogie
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
I need a main forward and reverse switch for a fellowes ds1 shredder.is that possible?
Have you tried calling Fellows? This link is to your operating instructions, which has phone numbers listed for different countries.
http://www.fellowes.com/Fellowes/Materials/Documents/ds1_2005manual.pdf
This link is for listing your model and serial number to inquired about what parts are available.
http://www.fellowes.com/Fellowes/site/support/support_faq.aspx
Dec 03, 2009 | Fellowes DM8C Cross-Cut Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
Paper gets jammed. Even shredding just one sheeet of paper. Clicking noise is heard before the red light comes on.
The problem was solved by putting some oil on the top of the shredder and running the motor forward and in reverse to coat the teeth. Thank you.
Oct 16, 2009 | Fellowes DM8C Cross-Cut Shredder
I have a DM8C that only runs for a couple of seconds at a time and then it stops. Toggle the switch back and forth and it feeds a little at a time until the page is completely shredded. It works okay in...
Common solution is to clean upper and lower sensors with cotton swab. If it still jams, then you will have to remove the top carefully and clean all paper shreds out of the housing. The paper shreds are most likely packed in the housing shroud and jamming or overloading the motor.
Jun 21, 2009 | Fellowes DM8C Cross-Cut Shredder
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
Where is the place where I oil my dhmc shredder?
I assume you are oiling the cutters if this is the case just run the oil into the throat where the paper to be shredded goes.
Apr 24, 2009 | Fellowes DM8C Cross-Cut Shredder
Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
May 16, 2008 | Fellowes DM8C Cross-Cut Shredder
Fellowes DM8C Cross-Cut Shredder Logo
256 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
