Question about PfaFF Tiptronic 2030
Pfaff 1222 Bobbin holder stuck with thread
A pfaff 1222. The bobbin holder has thread stuck in it and we cannot get it out. How do we take apart the pieces of the holder to get the thread out.
  • talk2ginny
    talk2ginny May 11, 2010
    Please don't take anything apart!!! I'm not sure what part of the machine you referring to - are you talking about the bobbin case, or the area in the machine where the bobbin case goes into the machine? I can help you with either problem, but if you take stuff apart, it will be almost impossible to put back together correctly.
    Please repost and describe your problem in more detail - it is probaby easier to fix than you think.
  • 632 Answers
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Posted on Jul 27, 2009
  • 3 more comments
  • Ed Paje Apr 26, 2010
    Remove the needle, sewing foot and the needle plate. Don't remove the feed dog or you'll have more problems ahead of you. Once you've done this you will have enough access from the bobbin area and on top of it to pull out thread. You could also try rotating the hook using the balance wheel so you can free the thread from behind the hook area.
  • Ed Paje May 07, 2010
    Remove the needle plate screws (2pcs) and lift out the plat, from there you can shine a light and see what's caught around it. NOTE: Do NOT loosen feed dog screws or else you'll need a repair manual and use the feed dog setting procedure.
  • Ed Paje May 13, 2010
    I remember answering this before. Remove needle plate to access the bobbin area and locate the tangled thread around the bobbin. Do NOT mess with the feed dog at all.
  • Ed Paje May 16, 2010
    This is the third time I'm answering this problem, it doesn't seem to register my solution.
    1. Place the presser bar all the way up
    2. Remove the needle
    3. remove the two flat head screws from the needle plate
    4. Remove needle plate to reveal the upper part of the bobbin
    5. With a flashlight, locate the tangled thread behind the bobbin.
    Note: Nothing else to be tampered with aside from the items above, this will maintain the machines integrity from it's state of operation.
  • Ed Paje Jun 01, 2010
    1. Remove the needle and remove the presser foot.
    2. Unscrew the two flat head screws with a flat head screw driver.
    3. Lift needle plate and set it aside.
    From there you have access to the bobbin area from above.
Mimito7
  • 128 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
talk2ginny
  • 34 Answers
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
Hi - it is possible that your needle is bent. Insert a new needle and check again - if you have the same problem, your timing is probably off. You could try buying a new bobbin case to see if that solves the problem. If you have had your machine tuned up within the last year or two, I would recommend a tune-up. If you know of a reputable sewing machine repair shop or dealer, the tune up should include correcting the timing and will extend the life of your machine.
Good luck,
Ginny
Posted on Jan 31, 2009
SewTechWayne
  • 186 Answers
SOURCE: Bobbin winder won't spin
The two most common problems are that you either need a new bobbin tire, or just need to adjust the position of the winder a little closer to the hand wheel. Remove the top cover and you will see the winder assembly. Loosen the two screws that hold the assembly nudge it closer to the hand wheel side. If you move it too far the winder will constantly spin. Also, examine the rubber tire, it may have a flat spot on it in which case it needs to be replaced. If it is worn out you may not be able to tell just by looking at it.
These winders can be tricky to adjust but why not try?
Posted on Feb 06, 2009
  • 10 Answers
SOURCE: Pfaff 2048
The timing has been knocked off when it jammed. The only way to
correct this is to take it to a shop and have it retimed. This is common on these machines.
I have 25 years working on Pfaffs
Posted on Jun 30, 2009
  • 980 Answers
SOURCE: Manual for a PFAFF 1222 sewing
Try www.sewingonline.co.uk/instructions or www.sewing-machine-manuals.com and click on relics, don't be put off by the word relics
Posted on Nov 03, 2009
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
A thread is caught in the bobbin apparatus. Took bobbin case out and machine is still jammed. Can I take it apart and get the threads out? What to do...
Only thing is to remove the bobbin, bobbin holder if you can, the feed dog cover plate, and then, using a magnifying lamp and a fine pointed pair of tweezers, try and locate the bits of cotton and pull gently out while rotating the hand wheel slowly, rocking it back and forth. Use an air blaster can to blow fluff out, clean, and oil. Including inside the bobbin case.
Feb 26, 2017 | PfaFF Sewing Machines
My pfaff 4.2 keeps saying remove thread jam under the stitch plate. I have cleared everything several times but it keeps coming up on the screen.
Candace, while not familiar with the 4.2, I've had thread jams on my trusty old Pfaff. I hope this helps!
If you are able to totally remove the bobbin cover/stitch plate, please do so. Ideally, there will be one or two screws holding it in place.
remove the bobbin
carefully inspect the bobbin housing; thread likes to hide behind the housing. If you find some thread, use a tweezers to remove it.
If no thread is found, see if there are one or two screws holding the bobbin holder/raceway in place, or just a lever. Try to remove the bobbin holder, carefully noting what the orientation is of all pieces is (using a cellphone to capture pictures of before and after is great!).
Clear any threads from the raceway, carefully re-assemble everything, test and good luck!!!
Apr 22, 2015 | PfaFF Sewing Machines
Thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Pfaff 2014 bobbin casing has thread - needs to be removed - how?
I had this problem with my 7570. I kept trying to wiggle the hand wheel. Took everything apart I could to get at it. Finally after many try's it moved and I was able to use a tweezers to get the tread out. A friend suggested applying a drop of oil to the bobbin case and letting it sit. She said it would desolve the thread some so you could move it.
Apr 03, 2013 | PfaFF Sewing Machines
Thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Nov 05, 2012 | Pfaff Creative 4.0 Sewing Machnie
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
Using a Pfaff Hobbymatic 935. Needle will not move, mechanism around bobbin will not move. Everything is locked in place. Tried cleaning everything, removed the needle (to get the fabric out of the way),...
It is likely the the bobbin holder is jammed up with cloth or thread. Take the bobbin holder out and turn the machine by hand, if it does not move it could have a broken timing belt or slipping coupling.
Apr 13, 2011 | PfaFF Sewing Machines
Apr 24, 2009 | PfaFF Tiptronic 2030
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Sewing Machines Logo
1,783 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
