Question about Technics SL-1210 Turntable
Sl1200mk2 how can i pitgh up my turntable?
It's very simple. Next to the "tone arm" (the thing you pull across towards your vinyl, and place down to produce sound) is a silver piece which you slide up and down to change the pitch (the speed) of the vinyl. This can be increased even further by changing the 35rpm setting (button near the start/stop button) to 45rpm.
Hope that helps
Posted on Feb 05, 2009
Bush technical helpline
I have answered the turntable question.
Audio leads are red (right) and White (left). Video leads are Yellow. I hope that answers the other part.
Aug 12, 2013 | Technics Audio Players & Recorders
Technics SL1200MK2 - audio issue with ''s'' sounds only
Try some anti-static record cleaner. You can also get an anti-static matt to put the records on.
Jul 27, 2010 | Technics SL-1200MK2 Turntable
Hi, I have a jammed height adjuster on a Technics SL1200MK2. Does anyone know a way of fixing this?
Quite often grit and dust gets into the thread and jams it up.
If the deck was in my workshop I'd remove the actual tonearm and phono cord etc and after applying a little penitrating fluid I'd "encourage" the arm base to unscrew - not subtle but somtimes a little force is needed.
http://www.technicsdjuk.com/
http://stores.ebay.co.uk/methleykev
Nov 11, 2009 | Technics SL-1200MK2 Turntable
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 02, 2009 | Technics SL-1200MK2 Turntable
Phono Preamp buzz
Don't forget to ground the ground cable from the turntable.
Sep 15, 2008 | Technics SL-1200MK2 Turntable
TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
Apr 08, 2008 | Technics SL-1200 Turntable
How do i replace the phono leads on my technics 1210?
OK,
you have to turn it over, remove the rubber housing, remove the round metal guard from below...
ONLY DO THIS IF YOURE CONFIDENT IN SOLDERING SKILLS!!
You have to unsolder 4 leads ( stereo ) and solder on a new pair.
If you actually proceed, i can give you a better step by step.
But this process requires soldering..so.
Keep me posted.
Oct 30, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
96 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
