Question about HP w1907 LCD Monitor
One of the buttons on the monitor doesn"t work
The negative button on the monitor does not work when i press it it acts just like the menu button. how do i fix it
  • Anonymous Feb 16, 2009
    buttem of the monitor menu press than monitor say osd lockout
  • 3 Answers
To solve an OSD lockout problem just follow one of the four fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Posted on Apr 12, 2009
Lmd 9050 menu button doesn't work
you will need to remove the back cover to access the button panel board. then check for a loose connector, if ok check for an stuck up switch in the button panel.
Nov 15, 2012 | Sony LMD-9050 Monitor
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
An emachine monitor menu keeps popping up and can't be turned off. what do I do
Press the "MENU" button on the monitor to turn it on or off. If that doesn;t work, press the AUTO button, let it reset and then press again to exit.
Good Luck
Nov 18, 2010 | E-Machines eMachines Monitor E15T4
When i try to adjust the monitor controls message comes up OSD locked, how do I unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Oct 24, 2010 | Computers & Internet
Just connected a HF 225 monitor to Vista Home 32 bit. No real manual; install CD does nothing. When I press the Menu or Brightness buttons on the monitor I get no response to keyboard or mouse clicks to...
They only include the Win7 driver on the CD. I'm surprised it doesn't work with Vista. Did you try going into the HF225_win7 directory and clicking on infinstallWIN7?
The monitor menu doesn't work with the keyboard. You have to press a combination of the three buttons to the left of the on-off button. It's not very intuitive.
Aug 08, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
I cannot adjust the color on the screen. Too Blue
mcdevito75 here, On the monitor itself press the auto button for factory settings, if this doesn"t work, press the menu button for adjusting contrast, color etc. if this doesn"t work your monitor may be going bad.
Jul 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Menu stays on screen all the time and wont go off even when pressing buttons .Off On button doesn,t work either.Could cig smoke gum up buttons
Cig smoke wouldnt effect the buttons, the control board on the monitor is probably bad, this is what tells the monitor to display the menu, make changes, etc... If that has gone bad, pushing buttons would have no effect. Youre probably better off buying a new monitor.
Jan 20, 2010 | Computers & Internet
Gateway FDP1975W Monitor Power Button Not Working
i would advice you to take your monitor to a technician, but if you are not ready, please leave the monitor on and make sure it is connected to ups u can now turn it on and off from the ups, if you continue the menu, Auto fit etc stuff, you might damage or disorganize the settings of your monitor which might cost you more. thanks
Jul 17, 2009 | Gateway FPD1760 17" LCD Monitor
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
HP w1907 LCD Monitor Logo
365 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
