Question about Toshiba 42H81 42" Rear Projection Television
Remote control not responding to tv
Toshiba model 42 wh 38b Rear projection tv is not responding to remote control. The batteries are ok I got the remote control (ct 90101) checked in a nearby tv shop. Remote control is perfect. Is something wrong with the tv itself?
Regards
Faizal
  • mohamodally Jan 31, 2009
    Yes the tv come on when i switched it from the power button Its just that the remote control that doesnt work on the tv. I cant change channel or change the volume ortherwise the tv can be operated manually without any problem. The only problem is that it cannot be operated with the remote control.
    Rgds
    Faizal
  • Mark Egan May 11, 2010
    Will the TV come on when the ON/Off button is pressed?
    President:
  • 1,214 Answers
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Posted on Jan 31, 2009
My Toshiba TV, Model 57HX81 quit responding to any remote control. How do we repair that or how much will it cost to have it serviced?
Does the rest of the TV work fine? If so, the problem is likely with the remote control. Have you replaced the batteries and made sure they are installed correctly? Did batteries recently leak in the remote to where the new batteries may not be making good contact with the metal springs? Has the remote been dropped a lot? If so, a solder joint may be broken for the IR transmitter.
If you have a universal remote that can be programmed to the TV model, that should make it easy to confirm if the issue is the remote or the TV.
Nov 26, 2016 | Toshiba Televison & Video
No remote control will work the tv anymore. Could
Hi I am Vortash , Its possible the IR detector has gone but unlikely , it is more likely that due to a low battery in a remote the signals have corrupted the remote processor this used to happen a lot with the old EMI and Bush sets and sometimes it is just a fact that the remote has given up the ghost . You can check to see if your remote is working with your Iphone or any phone camera . Put the phone on record and place the remote in front of the lens , if it is working you should be able to see the infrared diode flashing in the phones viewscreen . If it is working you will need to find out the de- corruption proceadure for your model of set hope this helps regards Vortash
Mar 30, 2010 | Toshiba 42H83 42" Rear Projection...
MODEL WS-65611 TV DOES NOT RESPOND TO REMOTE. HAVE REPLACED BATTERIES AND RESET THE TV. REMOTE LIGHT WORKS.
Is your remote one of the "universal" ones that allows you control multiple boxes?
If so, be sure you are selecting the correct input (TV, DVD, AUX, SAT...etc).
It's also possible that you will have to reprogram your TV to accept the remote's input. This can happen even if the TV and the Remote were sold together. Check your TV/remote manual for the syncing instructions and associated codes.
Oct 13, 2009 | Mitsubishi WS-65611 65" Rear Projection...
NEED HELP LOCATING INSTRUCTION MANUAL FOR T.V.
ct841 is the model of the remote. The model of the TV will most likely be on the back. Once you have the TV model, -->click here<--, this is the site to download the info you seek.
please take the time to give this solution a fix ya rating.
clarkco
Apr 11, 2009 | Toshiba 42H81 42" Rear Projection...
No remote control response (toshiba 42h81)
Are you SURE the cables are right?? The cable for the remote sensor and the speakers are both 4 pin and can easily be swapped. The cable with the brown wire (speakers) will attach to the convergence/signal PCB on the far right edge, while the remote connector plugs into a connector closer to the center of this board.
Jan 02, 2009 | Toshiba 42H81 42" Rear Projection...
Remote control for HCM4215W HDTV
Go to this link and leave a email with the model number of your samsung and let them know you need a remote . They will respond quickly and they will be able to get your remote fast.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Samsung HCM4215W 42" Rear Projection...
SHARP T.V. not responding to remote, but remote isn't broken
Here are the Toshiba codes for universal remote- 000,048,049,072,073,105,109,118,160,162,190,&241 try these codes and see if this works.ThankYou for using FixYa and Have a Nice day.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
378 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
