Question about Bose Wave Radio
AWR1 isn't working. Batteries new, hear thud when electricity con
Connected so I know that the wire is okay. I suspect a power supply problem, is that common to these radios? No other response from radio, just the thud.
  • 22 Answers
The power supply in your BOSE is easy to repair. Can you use an ohmmeter? The voltage regulator IC has 18V in and 10V out. Also Q1 often shorts from base-emitter. Both are easy checks if you know how to use a meter, and a cheap fix to get your radio working. Heck, I would BUY your radio if you want to sell it non-working!
Posted on Jun 30, 2009
    Problem Solver:
  • 16 Answers
Well im working on a bose radio now it is the am-fm clock radio and so far the dual bridge amp IC is bad along with a j111 n channel mosfet. these conponents are cheap and if you can do it i would suggest doing it yourself. the main capacitor check the soldered connections the positive joint is known to crack from the print on the board.
Posted on Feb 02, 2009
  • tim Feb 11, 2009
    i have new info to correct the problem most likely if interested email me and i will respond to you.
Hi Got a 2013 sgh honda 125 bike hooter just went
First check the fuse is okay. If it is okay, horns generally work by earthing when you press the button with the ignition on. Turn your ignition on, find the 2 wires that are connected to the horn and check if there is power to one. If there is, earth/ground the other connection and see if it works. If it does I would suspect the wiring. Alternatively, remove the horn, connect one of the electrical spade directly to the battery live and then earth/ground the other spade. If it doesn\'t sound then it is faulty and cheap to replace. Of course check all connections are clean and well connected.
Oct 02, 2014 | Motorcycles
2010 streetglide new fuel,plugs,bike pops and thuds no fire
Hi Richard, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 01, 2014 | 2010 Harley Davidson FLHX Street Glide
85 Chevy Surburban 6.2 diesel. Won't start. We charged the dead batteries and tried to start it. It started cranking then made a loud thud almost grind sound. We replaced the starter solenoid and Still...
Could be internal damage. Put a socket and wrench on the crankshaft pulley and see if engine is seized up. The thud is worrying, suspect major damage if the crank won't turn all the way round. If you can't turn the engine by hand, you will need a new engine (or new vehicle- that is a pretty old suburban, almost ancient to be needing a new engine!)
If engine still turns by hand, have your starter tested.
Oct 15, 2017 | Chevrolet Suburban 1500 Cars & Trucks
I have a HP Omnibook vl6200 running WinXP Pro. Works properly on the AC power, but shuts down if AC power is removed. Installed a new battery pack and battery monitor software showes battery is fully...
The first thing is to check if your battery is still okay by taking it off then measuring if it has some electric charge. If you are able to use a measuring meter then that's super but if you are not able to you can use a 24V truck light bulb and connecting with 2 wires to the positive and negative side of the battery. If it lights up brightly then the battery is okay. If it's got no electric charge then there are two possibilities either the battery is not okay or the charging system of the laptop is not working. Supposing your battery is okay. Then you need to have your laptop checked on the charging system. Remember laptop batteries do not last forever they actually deteriorate to until they are completely unrechargeable. So the Battery is my prime suspect.
Oct 07, 2011 | HP OmniBook XE3 Notebook
Computer will not turrn on hp a 1230n
Hi Raul,
Try this following instruction to isolate the problem.
1. Check the power outlet/AVR if it has an output, if okay,
2. Check the wire if okay, often times, the wire is damage or open. try to use another cable.
3. If the wire is okay, try to isolate the power supply, remove the power supply connection to the board and short the color gray and green wire to see if the power supply is working, if the power supply turned on then its ok.
4. It the power supply is working, try to check the power on button, it might have a problem. to override the power on button you can short the pins inside the board where the wire from power button is connected to motherboard.
Jun 27, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
LTV-32w1: Vertical scrolling on screen. Already replaced power supply and new power supply died. Saw reference to T-Con board. Can a bad T-Con board blow the power supplies or does it just send an auto...
Rolling or sync bars can be caused by bad caps in the tuner. I also had a brown film all over my board. Clean with alcohol and repace the 2.2/50 caps in the tuner. l
Sep 12, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Bose AWR1-1W older version, not Series III, no power, pop when unplugged.
I've got a simillar problem... will be looking into it this weekend. U402 is supposed to be the 5Volt regulator.
The input to U402 is U401 its a 12Volt regulator.
You should check both...
Mar 14, 2008 | Bose Wave Radio
Older AWR1-1W not series III
when you have the back up what suggestion you are asking from us sir?
sir please be specific with what you want
Bose wave AWR1-2W problem
I purchased one of these radios from a thrift store today. It had the exact same problem.
I replaced a 2SC3792 transistor located near the transformer/power supply section of the board. The transistor had a short between two of its leads.
once replaced with a substitute, the set came on and works perfect.
Nov 15, 2007 | Audio Players & Recorders
Bose Wave Radio Logo
333 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
