Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Mr Coffee stopped brewing
My Mr Coffee model FTX41 stopped working a few days back. It acts like it is going to brew but the coffee slowly drips out and it takes forever for the whole pot to finish. Also, the coffee tastes terrible once it is finally done. I've tried to run only water through in case there was a clog but no such luck... Is my machine dead?
  • melissazambr Jan 30, 2009
    Very helpful!
    I am certain the basket is clean.
    I will try the vinegar flush next.
    If that doesn't help are there any other options?
  • Anonymous Mar 17, 2014
    The water receptacle doesn't completely drain when making coffee
    President:
  • 1,214 Answers
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Posted on Jan 30, 2009
  • Mark Egan Jan 30, 2009
    Thanks for the kudo!
    No, when they get clogged up like that, they're hard to clean. At some point, you have to decide it's not worth the time to keep jacking with it, and go buy a new one.
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Feb 26, 2015 | Cuisinart SS-700 - Single Serve Brewing...
My mr coffee pot will not stop brewing when I pour a cup of coffee while it is still brewing. My model has the brew/pause feature
There may be grounds stuck in the spring loaded gadget next to the pot's pour spout - Remove all interior parts and rinse under water.
Sep 29, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Mar 01, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Mr. Coffee FTX41
Buy a new and different coffee maker.
Dec 10, 2007 | Mr. Coffee CBTU45
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
1,940 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Jim London
Jim London
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
