Question about Philips Magnavox 51MP392H Rear Projection Television
The screen is starting to have red and green blurring
My magnavox 51mp392h/17 is starting to have red/green blurring around the edges of the picture ( a few inches). I have tried to play with whatever controls I can figure out, but do not seem to be able to change anything.
Is this a problem that can be repaired or is my tv on the way out an dshould I plan to replace it?
  • Philips Master
  • 8,617 Answers
Sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Posted on Jan 31, 2009
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
Philips 51MP392H/17 - Red lines on the screen. When I block the red projector the lines go away and the picture is fine (aside from the color)
You have a red drive problem or possibly a bad red tube. There are a lot of parts between the signal processor and the red tube so it is hard to say what exactly is the problem. Have a shop check it out for you. Thanks for using fixya.
Dec 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Green blured color started at bottom left corner and growing
Based off manufactureing timeline it sounds like you have some capicitors going bad you will need to contact a qualified Service agent for a service call to repair the problem.
Jan 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H -- Multipoint Converge blue faded around edges
hey guys here is a great thread on this subject, its were I posted most of my pictures and there is a link to the manual in there. hope this helps,
BTW, IF ANY OF YOU GIVE UP ON YOUR 51MP392H/17 PLEASE LET ME KNOW!!!! I WANT TO BUY YOUR CONVERGENCE BOARD... "I killed mine" edwinkraus@hotmail.com
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/?page=1
Sep 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a magnavox 2004 51mp392h/17 prgection tv. The picture is crooked . The red & green are out of alignment. Can I fix this or should I replace it.
i have a magnavox t.v2004 but i dont have the control for the t.v and cant turn the t.v on .the t.v has light that saids standby
Aug 18, 2008 | Televison & Video
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
TV screen problems
convergnce IC are bad replace both of them that should straighten out your problem. But also check th resistors right next to th ICs as 1 or 2 of them may be oen as well
Mar 13, 2008 | Philips 51PP9200D Television
MAGNAVOX 51MP392H/17 CONCAVED PICTURE
There is a mode these set run in that stretches the side so the screen is completely filled, this is so the people do not seem all fat and short, this mode is known as Panoramic, this is one of the screen settings you can choose, I believe your set has a 4X5 or normal mode, 16X9 and maby a 16X9 zoom, the panoramic and maybe one more, find the format button on the remote and cycle through them
Mar 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
