Question about Brooktrout Technology Brooktrout TR114 P2L Modem
Brooktrout Tr114+P2L board in a RightFax server does not answer
2 port can send a fax just fine, but neither port will answer (even when attempting to dial the phone number from an outside line.
The RightFax server reports "Phone Line Problem", and you can hear one of those Special Info tones.
We can call the phone number of fax board internally, and it works just fine.
What do I need to do on this board and/or my ESI phone switch?
Tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
on Feb 15, 2011 | Office Equipment & Supplies
Rightfax 8.5 machine crashes daily at night between 12Am to 2:30AM. When checked next day, it has a BoD screen with System Memory Parity Error. System Halted.
Why are you still on 8.5? Not that 9.x is any better. Your best course of action is to switch to a solution that actually has real R
Aug 11, 2011 | Captaris RightFAX Business Server 8.5...
How to install rightfax on server 2008
Installing RightFax on Windows 2008 R2 is fairly straight forward if you follow the install guide and make sure all the prerequisites have been done. Writing out the entire instructions here would not really be that helpful. If you having issues, you may want to hire a RightFax reseller to assist with the install and migration from RightFax 9.0 to RightFax 9.4.
Jan 26, 2011 | Captaris RightFAX PDF Module 9.0...
I using rightfax 9.4.0,when i sent fax i receive phone line problem but i can receive the fax
What sort of connection does your RightFax server have to the TELCO?
Dec 08, 2010 | Cell Phones
What ''Fax server'' is good?
1) The first is the obvious one....Microsoft Windows 2003 Server! 2K3 server has basic fax services built right into the O/S for free. This is the perfect solution for a small office such as a real estate office or doctor's office. All you need is a basic fax/modem in the server, and you're ready to go. Server 2k3 can be configured to route faxes to a particular email address, print the faxes to a network printer, or store the faxes in .TIF format on a network share, or any combination of the three.
The disadvantage of this setup is that it does not distinguish between users or phone numbers. ALL incoming faxes will be routed to the same email address. Again, this is why I say it is perfect for a small office. My smaller customers use this method to simply route all faxes to a receptionist, who in turn reads the fax, figures out who it's for, and then forwards it on to the appropriate recipient. The fax server does not support multiple trunking phone lines and does not distinguish between recipients or senders, but treats all faxes the same. SBS 2k3 also supports this feature. Server 2000 does not support this feature, and no add-ins are available to add it, to my knowledge.
The MS software allows you to send a basic fax if it is properly formatted. I believe it only accepts .TIF files, but this is easily verifiable on Microsoft's website.
2) The big boomer in the faxing industry is called RIGHTFAX. This is a completely different animal than the basic little faxing package that comes with windows. Rightfax is quite expensive to set up, deploy, and support from Captaris is also expensive. However, the software is very powerful. The main difference is that RIGHTFAX can distinguish between incoming and outgoing faxes, and routes faxes directly to the users.
First, you to set up and reserve from the phone company a range of phone numbers that all "trunk" (or ring) to the same physical location. For example, I have ONE phone line coming into the building, but I want that ONE line to have 100 different phone numbers. So Sprint will set me up with all the numbers from 555-5000 to 555-5100 and they all ring to the same line.
Then RIGHTFAX does its magic. Using a special kind of "super modem" called a Brooktrout board, it can actually receive faxes on all of these lines. (100 lines is not the limit, I'm just using that as my example, the limit is crazy high, like over a thousand lines) Then, based on the phone number that was dialed, it can route the call to the appropriate user. It integrates in with Active Directory AND MS Exchange, so it can email faxes directly to Exchange recipients. It's truly amazing that it works at all, but it is very consistent.
Outgoing faxes are even more impressive. RIGHTFAX supports faxing in a variety of formats. You can feed it an MS Word document, .TIF, .jpg, excel files, Raw text, whatever...and it automatically converts it to fax format before sending it. The only format that is not supported is .PDF, but it is available as an add-in for an extra cost.
There are multiple ways to send faxes, also. The best thing about it is that it adds a button into MS Outlook. When you click it, you create your fax just like you'd create an email, including attachments, and when you click send, it is faxed automatically through the server. This is especially cool because it reads Exchange data, so you can pick a user off an exchange or outlook contact list, and the fax server will automatically use whatever phone number it finds in the "fax" field. It even puts the user's custom (virtual) phone number on the outgoing fax for easy replies. You can also print to a fax machine, or use their little quick fax utility to send one-time faxes. There are a lot of great options for sending.
The user interface on the server modules is a bit clunky, but you get used to it. Also, like I said, the software becomes expensive VERY quickly, especially if you figure in all the add-ins you need, plus the trunking lines from the phone company. It's not for everyone, but it's extremely powerful and versatile if deployed properly.
Their tech support is pretty good, they got me up and running in a week or so, and were extremely knowledgeable about their product.
I'm not sure if there's anything more specific that you wanted to know about the software, I could go on for hours, it's extremely complicated. But, if you have any more questions about either of those platforms, let me know!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 30, 2010 | Computers & Internet
I need drivers for the following device Tr114 up2L pci modem
opendrivers.com
Otherwise, go to control panel, then device manager, then find your modem and do a driver update from here.
lastly, you can get them from company website:
http://www.2point.com/FAXserve/FAXserve_Win_CDL.asp
Jul 09, 2009 | Brooktrout Technology Brooktrout TR114 P2L...
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
No answer from fax
There should be 2 telephone ports on the back of your fax machine. The telephone wire coming in from the wall needs to be in the jack called "line" or "wall" or something of that nature. MAKE sure it is not in the other port named "Tel" or "Accessory" or anything like that. Let me know
May 04, 2007 | HP 1040 Plain Paper Inkjet Fax
Brooktrout Technology Brooktrout TR114 P2L Modem Logo
1,911 people viewed this question
Top Brooktrout Technology Computers & Internet Experts
David Payne
David Payne
Are you a Brooktrout Technology Computer and Internet Expert? Answer questions, earn points and help others
