Question about 3M (40759) Floppy Disk Storage Media
Write-protect doesnt work
  • 624 Answers
If you have the gate on the floppy disk (do not confuse with the hole on the left side) open and it still writes to the disk then you have a problem I haven't had to deal with in 15 years. If it used to work and now doesn't then its the drive. There is a metal arm that "detects" the open gate, could be it isn't free to more or the spring is missing or damaged. If its never worked some PC BIOSs allow you to modify the locking mechanism. This could also be caused by a damaged or intentionally modified floppy drive cable. Back when software was distributed on floppies people who had to duplicate disks would disable the write protect feature. This allowed them to write on protected disks without having to go thought the timely process of setting the protection off to write then back on to send to users.
Posted on Jul 29, 2007
SOURCE:
It won't let me open a password protected disc
very simple , if you have just deleted/unistalled a software which locks/password protects the system then you must reinstall it . Secondly you make sure you unchecked all the software functioning options inside when you open it now . Lastly try unlocking the system using the same software given capability to unlock if there is one (try several times if it doesnt work the first time), if it doesnt work then try unistalling the software again manually reinstall option given by the software and not through the control panel ,So then restarting the system and then see if its unlocked now.
Now to Say thanks just Click on the following Links:
Http://www.HazratSultanBahu.com
Http://www.Haqbahu.com
Oct 01, 2012 | Iomega Computers & Internet
Is the external overload connect to the nurture line can protect the compressor?
if your compressor is shorted to ground then you need a new compressor. if you need help finding what compressor part# you need let me know. The external overload is there to protect the compressor from overheating, but if it doesnt work there is no protection causing compressor to possibly short to ground.
Nov 18, 2011 | True T-49 Side by Side Refrigerator...
My flash drive kingston 8 gb is write protected. how can i open my flash drive?
Hi.
Try these steps.
Carefully switch the write protect tab to Write enabled when inserting the flash in the usb "PC".
try using it. This happens mostly when you are inserting the usb, the tab is pushed to Protected mode without noticing.
If that doesnt work, i suggest you buy a new flash from different brand and less GB.
Good Luck
Nov 15, 2010 | Computers & Internet
I get the message "Protected Card"
on your memory card is a little switch thing. if it doesnt work one way try putting the switch in the other position
Jan 30, 2009 | Fuji Cameras
Display says Protect and doesnt work
the protection circut has kicked in and is stopping any further dammage
it will need to be looked at to determine the problem
Nov 01, 2008 | Kenwood VR-407 Receiver
LIghtning Audio B300.4 Protect Light
protect mode should be reset if the negative of your amp is disconnected then reconnectewd. if it doesnt help, move your ground to a different location. if THIS doesnt help, consider a repair or a new amplifier.
Jul 10, 2008 | Car Audio & Video
Amplight
disconect ur battary and wait 2 min. if that doesnt work then 1 wire could be grounding out..check wires for bad conection if that doesnt work then its probaly fryed
Jan 16, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
3M (40759) Floppy Disk Storage Media Logo
Top 3M Electronics - Others Experts
Marvin
Marvin
Are you a 3M Electronics - Other Expert? Answer questions, earn points and help others
