Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Double lettering sometimes
When watching the weather sometimes my 57' big screen shows wording almost in double vision does this require a repair man to fix the problem or is it something i can adjust
  • Anonymous Feb 02, 2009
    My double image is outlined in red! Fix Ya says its a possible convergence problem. Recommended solution is to go to your initial set up menu and follow directions to use Magic Focus, which is the automatic convergence adjustment. If that doesen't work....call a knowledgable TV repair person. It will requie a part replacemen........according to Fix Ya!
  • Hitachi Master
  • 5,138 Answers
IF you can solder you can fix it yourself.
Replace Both STKs Big black ICs and several resistors RK42 3.3 RK46 1.8 RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2
Posted on Feb 16, 2009
Turned the tv on and the bottom left looks like a turning page, picture is also blurred and words are double-vision. can this be repaired
TV needs convergence output ICs replacement as existing got defective and causing above said symptoms. These are two big black ICs on D board of tv that will be replaced.
Let me know if you have additional question.
Thanks.
Jun 21, 2010 | Sony KP-57XBR10 57" Rear Projection...
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
My Sony Big screen,57in.,Model #KP57WS510,the age-Feb.2004. I turned it on,it looks like i need a pair of 3-D glasses to watch it.Red and green outline the people or objects.Not so much in the...
The following convergence repair kit also applies to your model sony The kit contains the two convergence ICs all six pico fuses and four of the 4.7 ohm resistors. It also comes with free installation instructions and free tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Big screen TV
chances are the repair man wanted to sell you a whole board because with mitsubishis this problem is amost always the convergence ic's also in that model very seldom the resistors burn out in that unit its almost always the IC's that do that. I looked for you information you have an old chassis but I think its similar to the Vz2 I believe you need IC number STK391-020 thats based on theVz2 chassis but pls double check and you need 2 of them you can also save yourself if you know how to solder a lot of money by replacing them yourself its about a 45min job if I can help you any further pls let me know or if you would like a link where you can buy your parts very reasonable with tech online support let me know
May 08, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Double Picture
Goto menu and look for convergence control and realign colors.
Sep 22, 2007 | Hitachi 57G500 57" TV
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
