Question about KitchenAid KGST307 Gas Kitchen Range
Ketchen aid kgst 307
Hey all, For about 2 years i have had a problem, my stove top burners wont' light without my putting a match and lighting them, i know the igniter is bad, but how would i go about taking the top off the stove? thx so much
I get F2:e0 F2:e1 and F2:e3 as well as the continuous beeping. Unplugging does not resolve the problem, I changed the PC boprad on the side, what else can be wrong?
Posted on Oct 15, 2009
  • 5,911 Answers
There are several screws under the front lip of top of the range. You will have to open the oven door to see them. Once the screws are removed, the top should just lift up. Of course, if it has been a couple of years, grease and oil can creep into the seams along the sides and cause the top to stick. If this is the case, carefully take a putty knife along the side seams and lift up at the same time on the front. The top should open. Now, if ALL your burners are not lighting, that sounds like a bad spark module. Do you hear a clicking noise when you try to light any of the top burners? If not, the spark module not the igniters, is the likely suspect. The spark module provides a voltage to ALL the igniters simultaneously. Removing the top will not be necessary if this is the case. The spark module is usually located in the back of the oven cavity under bottom pan of the oven. Or, it may be located behind the panel in the rear of the stove. Let me know if this helps you.
Posted on Jul 29, 2007
SOURCE:
How do I switch the stove on when the electricity supply is off?
if its a gas stove you can light the burners with a grill lighter or match. the oven wont light without power
Jul 05, 2018 | Kitchen Ranges
Have a 4 burners gas stove top 2 burner gas igniters just clicking an wont come on
did you spill something on the 2 that will not light . that is the usual cause .some can be taken apart and cleaned others not so easy .try lighting with a match .
Dec 18, 2015 | Viking Cooktops
Primary burner won't light on electronic button propane stove
If it won't light with a match,then the orifice is plugged.If it will light with a match because you can hear the gas coming out,then your striker on the knob is bad.It's replaceable.
Apr 14, 2014 | Coleman 2 Burner Propane Stove 5430E700
Burners won't light
That clicking is the igniter trying to spark. Turn on the burner and attempt to light it with a match. If you know gas is comming out, you will most likely have to replace igniter.
Sep 26, 2012 | GE WB13T10045 Gas RanOven Igniter Glowbar...
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Stove burner will not light. I hear and see
There are two things I would recommend that you do . Check your burner mantle in the area where the igniter makes the spark for a small hole . It is a pilot hole specifically for the igniter . Sometimes it gets clogged with oil or grease. If that's OK, I would suspect you probably have a weak igniter control module , and you'll probably have to replace it .
Mar 03, 2010 | GE Kitchen Ranges
My gas was recently shut off for repairs from the gas company, now its back on and i dont know how to get my oven or stove back on
Ok you did not mention if your oven or stive had pilot lights or igniters. Given you asked the question how too turn it back on I have to assume it does not have electronic igniters. You need to light the pilot lights. There are 2 in top that are between each of the 2 burner sets. If you can not gain access to the pilot light by lifting the top of the stove up you can use a fire starter type lighter and re-light them. Sometimes they will self light if you just use a match on the burners.
As for the oven you can gain access 2 ways to the pilot light. One is to unlatch and remove the oven lower inside panel. The pilot light will be near the burner head. Just light it. The other is to remove the broiler drawer and reach way back in there to light the pilot light.
Again if you have igniter ignition all you have to do is turn on a burner or the oven. Good Luck.
Jan 22, 2010 | Ovens
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Mar 01, 2009 | Stoves Kitchen Ranges
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
KitchenAid KGST307 Gas Kitchen Range Logo
510 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
