Faint repeating hi...i just changed toner on this printer and when i print anything it seems that the image is faintly repeated on the paper...what can i do?...thanks roy
I have problem with my Phaser 6130 Laser Printer, I changed toners (black, cyan, magenta yellow). My printer printing only cyan and magenta, colors black and red is very, very light. I cleaned my printer exactly. Everything is ok, but he does not has a black & magenta toners. What's happen? I don't know.
Posted on Feb 13, 2009
HP 2600n Laserjet Ghosting. Prints multiple, faint repeats down the page. Changed all toner cartridges, still happening
Perform fuser cleaning procedure. If not helpful, replace the hot fuser roller. When worn out it collects toner and may lead to repetitive image.
Mar 09, 2017 | HP Color LaserJet 2600n Printer
Canon MFC-9150c Printing repeat down right side of paper only. Everything in center and on left prints fine. Tried a new toner, and visually inspected inside of machine. The repeat is very faint, but is...
You will need to replace the fuser. What has happended is the hot roller has lost its teflon coating and this is allowing the toner to stick to it, therefore the stuck toner is repeating do the edge of the paper until it disappears. A new fuser will cure it. It is user fittable to. You must have the power off when you change it. There is no reset for it just change it and power up and all will be fine.
May 09, 2011 | Office Equipment & Supplies
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
In spite of changing the black toner cartridge and toner waste receptacle, the printing remains faint
If your printer prints with faint vertical stripes like this
slamfix_22.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you Hope this helps you.
Dec 28, 2010 | Samsung CLP 300 Laser Printer
Our Laser printer doesn't print on the left had side of the paper--well, very faint--the right side is just fine. I just replaced the cartridge. What is the problem?
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Jan 15, 2010 | Samsung CLP 300 Laser Printer
The fusing unit uses heat and pressure to bond the toner to the paper. Normally poor fusing is evidenced by repeating images or by the print smearing when you rub your fingers across the paper. One fuser roller (the heat roller) is probably aluminum with a teflon coating and the other one (the presure roller) is a type of rubbery material and is often orange.
By your description you mentioned cartridges and that the printer is a full color printer. Is this a laser printer having toner cartridges and imaging units? I just want to make sure you do not have an inkjet printer as they do not use fusers.
The washed out prints you speak of sounds more like a transfer issue such as the transfer belt, transfer charge roller, etc...
Please tell me the brand and model of your printer and I will be more specific.
Nov 11, 2008 | Office Equipment & Supplies
HP LaserJet 2100/TN
Replace toner cartridge drum/blade RS, slim faint outside chance it is a fuser (hot bit rear) problem, doubt feed issue
To confiirm to yourself it isn't a feed issue, try feeding A4 via manual bypass (envelope slot) and doing a print using manual bypass tray, just override size missmatch warning if it appears (tick i think when beeping). should do same fault as feeding via cassete
You can also print a test page from printer via operations panel to confirm it is printer problem not software.and you can do a paper path test from whatever feed slot
To eliminate it being fuser problem try printing and turning the power off when paper is 1/2 way threw print job, remove cartridge and exaimine unfused (still image rubs off) print, if image is fine then it is a fuser issue but be carefull to note how much of a page needs to be printed before image repeats so you know if it is right or wrong.
But thats just tecnical possibitys, Change cartridge should fix!
Odds are 95% cart 4% fuser 1% others i reckon!
Oct 19, 2007 | HP Color LaserJet 2600n Printer
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
Jun 18, 2007 | Tally T8006 Laser Printer
343 people viewed this question
