Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
MOEN POSI-TEMP GOES FROM HOT TO COOL AFTER 30 SECONDS OR SO
THE 2 OTHER SHOWERS IN MY HOUSE WORK JUST FINE. THIS FAUSET WORKS OK IN THE SHOWER POSITON BUT IN THE BATH FILL POSITION IT SWITCHES TO COOL IN LESS THAN A MINITE. IF I TURN THE WATER OFF AND WAIT FOR ABOUT A MINITE IT COMES OUT HOT THAN GOES COOL AGAIN. I PUT A NEW INSERT IN THE FAUSET BUT DIDN'T HELP ANY. ANY IDEAS?
    Scholar:
  • 35 Answers
Wow A Mystery Faucet!!! SOUNDS LIKE THE WATER LINES FEEDING THE FAUCET MAY BE SWITCHED. CHECK TO MAKE SURE THE COLD FEED GOES TO THE COLD SIDE AND THE SAME FOR THE HOT. SOMETIMES MISTAKES ARE MADE WHEN INSTALLING THE FAUCET. MAKE SURE THEY ARE CONNECTED THE SAME AS THE 2 THAT ARE WORKING. IF YOU HAVE THE TIME AND PATIENCE, YOU CAN TAKE A WORKING FAUCET AND INSTALL IT IN PLACE OF THE (mystery faucet) AND SEE IF YOU HAVE THE SAME RESULTS. IF YOU GET HOT WATER IN THE TEMPORARY FAUCET, THEN YOU HAVE A DEFECTIVE FAUCET. THESE ARE A FEW TROUBLE SHOOTING TIPS I HOPE THAT MAY HELP YOU.....JOE
Posted on Jan 30, 2009
  • deputidave Nov 15, 2013
    NO I don't this that is it, I have the same problem, it is not the cartridge either, after reading a few of these solutions I am thinking that the lines are clogged with calicum or other debris from the water heater. I am going to pull my cartridge from the shower tomorrow and run the water through it to clear any possible blockages.
    Hey there pgearhart, I just noticed how old this post is, IF you ever found out the problem, and you still frequent FIXYA, I would like to know what the final solution was. Thks
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
Low hot water pressure on Moen Single-Handle Shower Only posi-temp shower control. Cold water pressure is fine. Hot water pressure elsewhere in house is ok. Cold it be the cartrige -- lime buidlup, etc.?
I think you are on the right track. The first thing I would do is change the cartridge. While you have the valve apart examine the inlet ports as good as you can to see if there is any mineral buildup. You can use a short length of a small gauge mallable wire to run into water ports to se if you can break anything loose. Another thing you can do is to turn supply stop on slightly while you have the valve disassembled to wash any particles out. Hope this helps you and thanks.
May 14, 2011 | Moen Posi-Temp Single HandleTub And Shower...
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
I replaced my Posi-Temp cartridge for the shower faucet. While the faucet now works fine, the pipes bang (water hammer effect)in the vicinity of the faucet every time someone shuts off the hot water. They...
no one ever really figured out why this happens, but you can purchase a "hammer arrestor" to solve this problem. they work good and believe it or not they are best installed at shower valve. good luck
Jan 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
I have a Moen Posi-temp single handle tear drop tub and shower that gives me no hot water
i am assuming you have hot water in same bathroom and that its fed by the same pipe? if so ask yourself did i have anything done recently that may have affected the shower ?if not i would think you have some kind of a blockage in fitting. one way to try to clear it is shut off water to house open shower fitting to what used to be the hot side when working,leave shower open,go o lowest level of house open hot side in sink you may get lucky and vacumn(think ****)debri from shower good luck .
Apr 23, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
265 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
