Question about Neff U1421 Double circotherm Electric Oven
Neff oven u1421 not heating up
I have changed the heating element which had blow but the oven will still not warm up could the thermostat have gone as well?
chris
  • 3 more comments
  • chrisc19 Jan 31, 2009
    i have taken the oven out to look at the back but there no sign
    of a overload sensor to reset
    thanks for the reply!
    chris
  • chrisc19 Feb 01, 2009
    hi again mrmark
    Im to to good at electrical troubleshooting, is the thermal fuse fixed to the centre oft he oven back which is conected to the element and the thermostat i have no wiring diagram. Would it be best to replace the thermal fuse before the thermostat
    cheers again for your help
    chris
  • chrisc19 Feb 02, 2009
    i have ordered a thermal fuse which will arrive in aday or two so will let you know the outcome on wedenday cheers again
    chris
  • Mark Egan May 11, 2010
    Take a look at the wiring diagram to make sure of the sensor. They are usually buried behind some sheet metal.
    You might also check that there may be a blown thermal fuse. It's a round, bullet shaped aluminum device about 1/2" long (~12mm), 1/8" diameter (~3.5 mm) that will be in the wiring harness. When they blow, they have to be replaced.
    How good are you at electrical troubleshooting? I can lead you through the process if you want to troubleshoot.
    Probably not, but did you check the the overload sensor did not trip? It has to be reset manually, and is usually located on the back of the oven.
    Make sure you are closing the oven door to allow the element to get hot. Some ovens have a door sensor and will not allow the element to heat when the door is open.
    President:
  • 1,214 Answers
If you have an Ohm meter, then test anything you feel is failed. No sense in replacing good parts.
I am surprised that there is no wiring diagram somewhere on the unit, like in the control head, or on the top or back (most units built in the U.S. over the past 30 years have them. Don't know about UK, which is where I assume you are.).
Let me know! The overload on the back should have a red reset button. The thermal fuse has to be replaced if it's failed, and normally when it fails, the control head will not work. It usually does not carry enough current to power the elements.
Posted on Feb 01, 2009
  • Mark Egan Feb 02, 2009
    Chris,
    Was the thermal fuse bad?
Our Neff U1421 double oven has a problem with tripping the main fuse when the main oven reaches 180 degrees. The oven is in manual mode not using the clock timer, can you throw any light on the proble
yes i know exactly whats wrong, one of your high accuracy temp sensors will have gone.
these tell the thermo what the sides & top of the oven temp is.
unscrew the oven from the base unit & pull it out, take the top off & you'll see them little round cylinder looking things with 2 wires coming off them(see link for pic) there screwed to the shell. the one that will have gone will no doubt have burn wires, or connections.
their sometimes called temp switch sensors
http://www.bi-metal-thermostat.com/photo/pl1619154-ip00_ceramic_bi_metal_thermostat_temperature_controller_for_micro_wave_oven.jpg
Sep 29, 2014 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1421 Double oven,
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Our 10 year old neff U1421 has just gone bang and has blown the fuse and left a white/grey film covering the complete inside of the oven. Is this repairable and if so, what part/s do I need?
sounds like the element has burned a hole through itself,, check with a local dealer for the element,, be sure to replace the contacts at the wires when replacing
May 22, 2011 | Neff U1421 Double circotherm Electric Oven
Oven has stopped heating up
If the fan is working o/k, then it is almost certain to be the element that needs to be replaced
This is located at rear of oven compartment, behind removeable cover.
Please rate my solution.
Thanks.
Nov 22, 2009 | Neff U1421 Double circotherm Electric Oven
I have a Neff U1721 circotherm oven. The lights come on and the fan works but it does not heat up. What could be the problem?
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Nov 13, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1421 Double circotherm Electric Oven Logo
869 people viewed this question
Top Neff Ovens Experts
bosch5
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
