Question about Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
I have a Samsung 215TW SyncMaster 21 inch Analog/Digital LCD monitor that flickers when I turn it on. The flickering slowly becomes less and less until after a 30-40 seconds the scren is perfectly normal. This also happens when I am away from the computer and the screen has gone to black... I press a key, the screen turns on and flickers for awhile then it's fine. The monitor is 1 year old and I have had no other problems with it.
Any idea what the problem is?
  • 3 more comments
  • nolosretep Feb 06, 2009
    I have the exact same problem. My Samsung 226 BW (R) S LCD/digital/analog is a 23 incher, I've owned it for a year and a half (made January 2007). The flickering started a month ago. Curiously, it flickers only when I boot up after it's cold. If I restart, for example, and monitor is still warm, no flickering. The length of time it takes to return to normal keeps getting longer. Now, it takes 5 to 7 minutes to stop flickering.
  • Anonymous Feb 10, 2009
    When the monitor comes out of sleep mode it flickers then goes black. Only a coold reboot of the PC returns it to normal.
  • Anonymous Feb 15, 2009
    Same issue with the SyncMaster 215tw. Happens on cold starts only. I have updated the drivers and tried it on a different comp with the same results. The problem is getting worse and takes longer to stabilize.
  • fxt2 Mar 13, 2009
    I've got exactly the same. Started about a month ago for no apparent reason - i used to be able to fix it by turning it on and off randomly after booting my computer, then pulling out the cables etc.. the flickering increases in frequency and brightness until either - maintaining a steady horrible bright/dark fast flicker or going black. If I leave my computer on for days, no problem whatsoever. Any ideas?
  • sasharris Apr 22, 2009
    Just started happening. This is not a slight flicker; this is unreadable.
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
  • Samsung Master
  • 1,684 Answers
The screen flicker is a common issue with this series of Samsung monitors that have been in use for several years. This is an indication that the capacitors in the power supply board are failing. The capacitors are used to filter and smooth out the voltages coming out of the power supply board and when they strt to fail they can't filter the power so the voltage varies and this causes the picture ti flicker. The problem will get worse over time until the monitor will not power up. The power supply board is easily repairable and here is a link to a service guide that shows how to dis-assemble the unit and what to look for and replace. The guide is for the 214T but the power supply board is the same NP-20 board.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Posted on Jan 12, 2012
The backligt stay fickers contineu
Flickering or wavy picture is a very common symptom of failing capacitors in the power supply board. This is a very easy repair, it just requires replacing the 6 capacitors on the power supply board. Here is a link to a repair guide for the SyncMaster 214T which uses the same NP-20 power supply board so the repair information will be the same.
I hope this helps,
BuddyMc
Dec 22, 2011 | Samsung 215TW SyncMaster 21" LCD Monitor
My Samsung SyncMaster 215tw stays in power saving mode with the blue power button flashing and won't turn on.
I'd verify all the cable connections first.
You could be dealing with two different problems, bad monitor, or a bad videocard/pc.
I'd swap the monitor out to verify that the computer is working as it should first. Once you determine that the PC is in fact fine, my suggestion would be to change the resolution on the PC to a lower setting then normal. Once that is done Plug the Samsung SyncMaster 215tw back into the pc and see if it powers on.
If it does not, i'd check the cables and swap them with something else to make sure thats not the problem. If you have another PC available, i'd test the monitor on that PC to make sure that it is not the issue.
After all that you'll come to the determination on what the problem is. Sadly, if the LCD is bad you'll have to replace it as they are extremely expensive to repair and generally not worth it.
However, i'd verify if it is under warranty or not, you never know! you might be able to get it fixed for free :D
Mar 01, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
How do I get sound from my new Samsung monitor. Everything works fine.
Here is the user manual: http://www.retrevo.com/support/Samsung-215TW-Monitors-manual/id/278ag702/t/2/
Just get an audio cable with mini stereo phone plugs at both ends, attach one end to the PC audio line out jack (Green), the other end just goes to monitor audio line in jack (green).
Apr 01, 2010 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung syncmaster 215tw monitor flickering
The capacitors BigTech referred to are C110 & C111, 820uf-25V Electrolytic, on the power supply board.
With minor soldering skills, you can replace them with Radio Shack in-store capacitors, Stock # 272-1032, 1000uf-50V Radial Lead Electrolytics for $1.59 each. Works great!
Four bucks and little bit of time saves the monitor.
Jul 01, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Open Questions:
Having issues on Acer Product ' call +1888784-9316 Care Number 24/7 Helpline Acer is a Taiwan-based electronics multinational that is best known for its computer products, although it also produces other consumer electronics such as personal digital assistants and mobile phones, as well as computer-related products such as servers and storage devices. Acer has ruled the consumer electronics market because it has the most innovative approach. Acer laptops are famous for their energy efficient performance with long lasting battery life, high portability due to the laptop's light weight construction, along with the added features like high speed Bluetooth and wireless connectivity and also wide screen display that provides exemplary image quality with higher resolution. Because of all these and many more qualities acer support have made it to the top of the list of customer's choice for best laptops. But its users might face some issues from time to time that could prove to hinder their important work and so, to prevent this, we have a team of technically superior and experienced technicians who can be contacted anytime on our toll free call acer tech support number. Issues faced by Acer customers:- • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues in acer computer support • Windows 10 upgrade problems • Computer Tune up issues • BIOS update • Virus removal issues Call on our Acer support phone number acer customer service and get all these issues and many more related to Acer laptops, addressed by our technically advanced and experienced support team members. Our Services: If you have any query or issue related to Acer laptops that you want to get resolved in the most efficient way possible by some of the greatest minds in this job with highest levels of experience then contact us on our toll free Acer support phone number. Contact our technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our acer technical support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 18, 2018 | Acer Computers & Internet
See all Samsung 215TW SyncMaster 21" LCD Monitor Questions
Samsung 215TW SyncMaster 21" LCD Monitor Logo
3,761 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
