Question about Toshiba Tecra A3 Notebook
Power when i turn my laptop on it turns off after very instantly.i have set my power settings so that its always on but it just keeps turning off
  • ed umana Jul 29, 2007
    how do i get it repaired
    Problem Solver:
  • 6 Answers
What you should try now is to try and power the laptop while it is ONLY on battery power. If that doesn't work, then pull the battery out and try and turn it on while ONLY on outlet power. If it works while only on battery power, you probably have a failed power adapter. If it only works on outlet power, you probably have a failed battery. If neither method gets different results, it's likely to be a failed component on the motherboard.
Posted on Jul 29, 2007
SOURCE:
Digihome 48304 keeps turning off
If it is after a period of time. Then you have auto standby on. Select it and set it to off.
If it turns off almost instantly then you have a fault in the set's power supply.
May 27, 2018 | Televison & Video
My laptop keeps turning off the display in 3minutes,and I keep resetting it to 10 min,whats the problem with it not recognizing my settings.
Do you hit "Apply" when changing the settings?
It not enough to say OK.
Check the settings after you have come out of the power setting, by going back in again, before turning off the laptop.
Oct 10, 2014 | Computers & Internet
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
Display broken
COST WILL ALWAYS JUST FOR THE PART EXCEED THE COST OF A NEW SET. Also if set was on or turned on after that even for an instant other boards in the set may have instantly suffered damage.
Nov 08, 2012 | Sharp LC60LE835U 3D LCD TV
My laptop hasee f420s always off after working for about 10 to 20 mins, what is the problem.
Hi
is it the hard drive that is turning itself off because on most laptops the default setting is set to turn off after 20 mins also the display turns off after a short time
if this is your problem you can alter the setting in start control panel power options
hope this is the problem and that you can alter the setting to what you require and please press apply or save settings before you close the power options box down or the settings you alter will not save
good luck
Apr 24, 2011 | Computers & Internet
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
Backlight on Flybook V5
Hi Piergiorgio,
Nothing in the registry or BIOS however, in the Flybook control center, you can manually set your brightness on the system and turn off auto backlight. That way the system will always turn on and your system will always remember the setting of the back light.
Let us know if that helps!
Feb 17, 2010 | Microsoft Dialogue Technology Flybook V5
What shld i do if asus laptop is in zzz mode and it wont turn on?
Try this simple solution- press on the power button for a very long time, until the laptop stops working.
After the computer shuts down, turn it on again and look for the sleep settings, sometimes the computer is too eager to turn off the display. You'd be surprised how many computers have troubles waking from their sleep (maybe they need to call the charming prince). Anyhow, check the settings for the computer's sleep. I always ensure that my laptop won't independently fall asleep, always by button.
Nov 05, 2009 | ASUS Computers & Internet
Screen brightness keeps going down.
its because it has gone into power saving mode, you need to go into the power/battery settings and set the brightness at 100% and then choose that setting as default.
Sep 06, 2007 | Toshiba Satellite M30X Notebook
No signal from router after closing laptop
Is it definately the router that's your problem, because most laptops are able to turn off the wireless connection especially when powered by battery alone to conserve power, so check the settings in your laptops wireless adapters properties.
Jan 28, 2007 | NetGear DG834G Router
Toshiba Tecra A3 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
