Question about HP OfficeJet 6110 All-In-One InkJet Printer
I have never hooked up my fax portion of the 6100 hp.
I need a simple step by step from beginning to end.
    Genius:
  • 2,120 Answers
You should have a dedicated ANALOG phone line.
Hook phone cord from wall jack to LINE port of the fax machine.
Ready to fax.
Posted on Jan 31, 2009
I need to know how to hook my printer up for receiving faxes and scanning options. it does everything else. is there a sight i can download this part of the manual?
The steps are simple
Connect the 2 wire phone cord at back of printer in EXT 1 ( this is for incoming and outgoing for Fax )
Press the setup button printer
Scroll to Fax Settings
Set the Rings to Answer ( +2 from your Voice mail rings, if someone reaches your voice mail on 4 rings, set 6 Rings to Answer )
On the printer front panel is a Button Auto Answer - turn it ON
You are ready to send/recieve Faxes
For more details about Fax features you can download the manual of this printer from this link
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Jun 25, 2010 | HP Officejet 5610 All-In-One InkJet...
KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Jan 03, 2010 | Pentair Kreepy Krauly Inground Automatic...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Under the catagory- Winding Bobbins it says to release clutch holding hand wheel and turn the know toward you. Ours sometimes works and sometimes jams together i.e. won't turn
Hi
You can follow this procedure to wind the bobbin thread--
Step 1--Secure thread on sewing machine as if you were threading machine and pass thread end along indicated thread guides. Thread guides will be somewhat different for bobbin winding than for regular threading.
Step 2--Place empty bobbin on bobbin winding spindle. This spindle will be located on front right, on top right, or on either side of machine. The spindle may have to be repositioned for bobbin winding.
Step 3--Place thread end through one hole in upper portion of bobbin, and pull a few inches of thread through.
Step 4--Disengage the sewing machine needle by either pushing in the center portion of the handwheel or rotating center portion of handwheel towards you. The method will depend on the model of your machine.
Step 5--Take hold of the thread end and pull gently outward so that there is very little slack in the thread. Firmly grasp thread end.
Step 6--Push on presser foot to begin winding bobbin. Hold onto thread end while bobbin is being wound. Wind bobbin only up to guideline marked around the edge of the bobbin.
Step 7--Cut excess thread from the top of bobbin and cut thread that attaches bobbin to rest of thread spool.
Step 8--Insert bobbin into bobbin case, pass thread through indicated slots, and bring thread out a few inches to the right.
Step 9--Close slide plate over thread.
Step 10--Continue threading machine.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 07, 2009 | Office Equipment & Supplies
Fax will not pick up
Review this web page. HP may be able to help you out.
Apr 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Unable to use Fax machine with cable company telephone.
You don't have the cable plugged into the "telephone" jack instead of the "line" jack on the machine do you?
Mar 13, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't send or recieve faxes
Step three: Use an analog telephone service HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service. To obtain digital services information or support, contact the telephone service provider or system administrator.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Hp5610
hello with witch windows do you work???
Jan 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
