Question about HP Pavilion F1703 17" LCD Monitor
Hp 1703 Please Help if you replace the main boards ( power & Video Or just the Power Board) will this fix the display issue. thanks
3 Suggested Answers
  • 96 Answers
SOURCE: Hp 1703 Video for 1second
Probably something wrong with the monitor's power-board. If you are good enough in electronics and soldering, disassemble the monitor, unscrew the board. Check the cables, connectors, blown caps and fuses (some of them may doesn't look ordinary) first. Look for the dry joints, especially at transformers. Resolder all the connections. Test power transistors. You should unsolder them to test properly.
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: Hp 1703 Video for 1second then Black but can see it but wery dark
sorry, not really a solution, but may help point you in right direction. I have similar or same problem with my monitor but is an f1903 (HP). I recommend you look at the f1903 board postings to see those answers. Several seem identical for fixes and fix may possibly be cheap, but unfortunately noone has posted how to open the monitor up to actually check it inside. This is the tricky part, as seems no catches or buttons are present and removing back screws do not let the monitor case open without some type of special trick or move. If you figure it out, please tell us all! Thanks
Posted on Feb 12, 2009
Flashing Logo/no picture even After replacement of Power Board.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 09, 2017 | Vizio XVT423SV 42" 1080p 240Hz Tru LED VIA...
Dead Vizio V047. No picture, no sound. I do measure 5v dc on three of the power supply board pins going to main board but I don't think the main board is sending a signal back to the power supply to...
Modern Displays/TVs cost more to fix than they are worth, plus electrical problems can become a fire hazard.
I suggest recycle this and upgrade to a new one.
Nov 19, 2017 | Televison & Video
My lights on my LG CW2016CW (Frontloader) do not display. I only hear a beeping sound when I press the start button. Can someone help me diagnose this issue? Fuse replacement? Is there a way to reset...
There is a main fuse to the main board and if you take the top panel out by removing the side screws this can be seen. Now checck th power to the main board. If this is present then the power supply within board or the processor has failed. You might need to replace the board.
Jul 27, 2011 | Washing Machines
I have LG 50PC3D-UD display issue. I'm getting a black screen with thousands of blue pixels in center of screen. 5-6 inches wide orange horizontal from top to bottom moving across the screen. I check and...
The reason the blue pixels are igniting is caused by the driver board, not the power supply or main board. The drivers are part of the LG screen and cannot be replaced.
Mar 08, 2017 | LG 50PC3D 50 in. Plasma Television
I have one Samsung HP-R4252 no give video and sound, I check all fuse it's good, check all voltage are good, only turn on the led in power button and flashing when press any key in the remote control, I...
try replaced main Y assy board or power supply board
Manufacturer Samsung Part Number BN96-02033A Description ASSY PDP P-Y MAIN BOARD
Manufacturer Samsung Part Number BN96-02213B Description ASSY PCB P-SMPS
Sep 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Hp 1703 Video for 1second then Black Please Help if you replace the main boards ( Power & Video Or just the Power Board) will this fix the display issue. thanks
You may want to check your power and connection cables are not showing bare wire, which is the metal hanging out of the rubber insulation cord. So just check for that and if not that I would call HP.
Jan 30, 2009 | HP Pavilion F1703 17" LCD Monitor
Dell W3000 display issue - logic board or inverter?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
HP Pavilion F1703 17" LCD Monitor Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
