Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Kenmore electric stove dual burner goes to high heat.
Dual heat surface element will heat to high on both inner and outer elements. i.e. turn switch to single lo inner element goes to high heat, turn switch to dual lo and both inner and outer elements go to high heat. Is this a dual infinite switch problem or could this be a limiter switch problem on the heating element? Not sure how the limiter switch works.
  • Mark Egan May 11, 2010
    Are you watching the elements without a pan on the burner?
    I believe the sensing system requires that there be a load on it (in terms of a mass, not weight.).
WhIzAtIt
  • 136 Answers
SOURCE: Burners are not fully heating out to the end
Either the elements are going out or the controlls for the burners are getting croded contacts. Best bet would be to replace both and go for another 7 years :-)
Posted on Sep 15, 2007
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
Eddie Rentas
  • 59 Answers
SOURCE: Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
aborcass
  • 2651 Answers
SOURCE: Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Posted on Nov 04, 2008
jtbjtb
  • 135 Answers
SOURCE: JEC9530, dual element burner(right front) does not
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Posted on Feb 26, 2009
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
My Viking VECU105 electric cooktop has one burner which will not regulate the temperature. It can be turned on and off with the control knob, but after that, there is no temperature control. Any ideas on...
It will need either a dual infinite or infinite switch, If the burner has an inner an outer element then it requires the dual.
Firstly turn power off at breaker.
The unit needs to be removed from the cut out and the cover removed from below the swtichs. the knob taken off and the secureing screws removed, then take note of the layout of the wiring and the poistion of the switch, then swap the wires, reassemble test and then re-install
Feb 18, 2009 | Viking 31 in. VECU105 Electric Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
142 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
