I was watching a dvd and was finished. Took it out and closed the try. I wanted to switch to watch a movie on the vcr but it wouldn't switch over.
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
SOURCE: NB500mg1f won't play DVD, watched
Buy a cd/dvd lens cleaner they run about $8-$10 at the store. If that doesn't work the laser is probably bad.
SOURCE: I have a Magnavox Digital Video Disc Recorder
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
SOURCE: Hello! I am trying to
You are probably using a disc format which is not compatible with this model unit. Try using DVD-R instead of DVD+R. That should eliminate your error - and work fine. Give it a try - at this stage it is most likely a set of incorrect DVD formats (you can keep any unrecorded/remaining DVD+R discs for your PC (if it supports them) and use them as data storage).
* Single layer DVD-R 4.7GB/120min/4-16X discs are relatively cheap in a spindle tub (25 or 50 discs) available everywhere. *
The good news is no repair costs at this stage.
SOURCE: my VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
