Question about HTC PPC-6800 Smartphone
HTTC 6800 Not receiving calls in sleep mode - HTC PPC-6800 Smartphone
  • Anonymous Feb 11, 2009
    I have the same problem. Do not even know I am getting a phone call until I pick up my phone, but then it is missed.
    Scholar:
  • 61 Answers
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Posted on Feb 04, 2009
Cannot receive calls in sleep mode on xperia arc s
This is a software issue.
Please take it to an authorized service center and downgrade the software.
Dec 12, 2017 | Sony Ericsson Xperia Arc S
PRINTER WILL NOT PRINT DCP 8060 LASER NON USB PRINTER SAYS SLEEP
Have you tried turning off "energy saver mode" in system settings?
Feb 10, 2010 | Brother MFC 6800 All-In-One Laser Printer
Lcd says sleep 10: 35 fax. What does that mean?
The machine goes into the sleep mode after the amount of time you set to conserve energy. It is sleeping and will wake if a fax comes in, fax tells you it is in the fax mode and not the manual mode or fax/tel mode. 10:35 is the time of day.
Oct 13, 2009 | Brother MFC 6800 All-In-One Laser Printer
Jawbone original seems to go into sleep mode. If I have not received a call for a short time, the Jawbone seems to go into sleep mode and I am unable to answer an incoming call with it. I have to answer...
I have a Jawbone and have not experienced those problems. You may have a connection issue with your phone. Maybe the way your blue tooth is set on the phone....power settings?
Oct 03, 2009 | Cell Phones
Turning off flashing light
Install this app nueLED and check off disable Signal LED...no more annoying blinking light...
http://www.1800pocketpc.com/2008/02/25/nueled-15-configure-leds-on-any-htc-device.html
Jun 30, 2009 | HTC PPC-6800 Smartphone
Flashing lights
You can't it lets you know that the power is on even when the screen is off in sleep mode. You can still recieve call when it is like this if it is not blinking it is off and will not recieve calls or use anything else without waiting for it ti power up and boot up much like your PC.
Dec 31, 2008 | HTC PPC-6800 Smartphone
Nokia 6800 won't ring
go to profiles settings, then select GENERAL........
sexy-ym
Sep 04, 2008 | Cell Phones
SLEEP MODE PROBLEM
I had this problem with one of my copiers once. I called to service technician. He reloaded the most recent system software. That solved the problem.
Aug 21, 2008 | Canon IMAGERUNNER 6570 Copier
"Receiving Sleep" on Brother Fax 4100
you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Sep 04, 2007 | Brother IntelliFAX 4100 Laser Fax
HTC PPC-6800 Smartphone Logo
407 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
