Question about Garmin nuvi 200W GPS Receiver
The unit does not boot
If i connect the unit at the PC,it is not reconignized.the display is black only with the garmin title,and do not open nothing.....apologies for my english
    Brigadier General:
  • 5,158 Answers
Mine does that too... it's charging the battery ... you can still use the garmin updater from www.garmin.com to update the gps.
Robert
Please take a moment to rate this solution thanks
Posted on Jan 30, 2009
GPS Nuvi 1350 not booting past Garmin screen
In order to access the unit's internal flash drive, a service firmware needs to be flashed on the unit. This will allow the unit to boot only as a flash drive and a PC will now recognize it. The backup files may now be transferred over to the unit. Then the units firmware must be flashed with the normal factory firmware (v6.3 as of 3/8/16). More info on boot-up issues can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Mar 06, 2016 | Garmin Nuvi 1350
Gamin nuvi 1450 wonot start and the gamin express cannot recognize it
Your Nuvi has to boot past the Garmin logo to the main screen before it can be recognized by your PC. Is the unit dead? The Nuvi 14xx series is well known for its problem with the rear USB port coming loose. This will prevent the unit from receiving power from the external charger and will prevent the battery from being charged. If the unit goes into a boot-up loop, displaying the Garmin logo then shuts down, this is often caused by corrupted files, such as a map or bad firmware update. See these two links for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Nov 01, 2014 | Garmin nuvi GPS
Hi I have a garmin nuvi 1410 that after booting
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. A software update should solve the problem.
Mar 28, 2017 | GPS
Gps
It can not be reset. The unit has to be flashed with a service firmware to access the units flash drive. Then the missing or corrupted files need to be replaced. This is why the unit is crashing on boot-up.
Once the files have been restored then the unit can be reflashed with the factory standard firmware.
The problem you have right now is that the unit can not be found by your PC because its in an endless loop-boot-up and never reaches the main screen to detect that it is connected to a PC.
For more info on boot-up problems, please see this link:
http://www.sharc.net/gps_bootup_repair.htm
Apr 13, 2013 | Garmin nuvi GPS
Garmin Nuvi 260W will not boot following software upgrade.
I have the same problem! I called support and the final solution was to send it in, get a refurbished replacement, and pay $80.
Feb 06, 2010 | Garmin nuvi 260W GPS Receiver
Garmin 545s : The unit powers up, the keys are illuninated, however, the display creen is blank (black no image). The unit beeps when I push the + and - keys and menue keys, but no display?
I recommend upgrading the system software of your Garmin 545s. There may not be physical damage to your unit, and it may be completely revitalized by replacing the GPSMAP software with the latest version 5.30 (as of January 7, 2010).
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
I hope that helps.
Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
My Garmin 265wt will not turn on for navigation when connected to a computer anymore. It displays the computer connection but I cannot get to the navigation while charging like I had before. Any help how...
I asked Garmin how to display maps when connecting a 265WT to a PC with a USB cable. Based on the following reply I received from Garmin the answer is you can't. Have you ever updated your software in your Garmin 265WT. Perhaps you were able to display a map with the USB cable connected with an earlier version of the software. Whereas the latest version of the software will not let you display a map with a USB cable connected.
"Thank you for contacting Garmin International.
I will be happy to help you with this. Unfortunately when your unit is
connected to a computer you will not be able to use the device. The unit
is designed to go into mass storage mode when connected to a computer."
Sep 20, 2009 | Garmin nuvi 265 Car GPS Receiver
I get the message "system, halted check cable"
Open your System unit and make sure all components are properly connected. your hard Disk Cable might be loose or damaged etc...
Jul 05, 2009 | Gateway 700 XL PC Desktop
I have a street pilot c550 and it will not boot up. It gets to where it says loading maps then it goes black
I found the resolution on this site. I removed the face of the unit and hit the reset button on the right side of the unit. I put the faceplate back on. I connected the unit to my laptop via USB port. I downloaded the software for the c5550 from the Garmin site. I installed the base software and the upgrades. I left it connected to the laptop for a few hours to fully charge. I then disconnected it from the laptop and hit the red button to turn the unit on. I received a software update message, when that was done, the unit completely booted up.
Dec 13, 2008 | Garmin StreetPilot c550 GPS Receiver
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Apr 08, 2008 | Computers & Internet
Garmin nuvi 200W GPS Receiver Logo
71 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
