Question about ViewSonic VX1962wm LCD Monitor
Display problem with ViewSonic VX1962wm 19" wide monitor
Hi. I'm having terrible problem connecting the ViewSonic VX1962wm 19" wide  monitor on ASUS EAH 4670 512mb DDRIII graphics. Display will not accept any display driver software. When I install drivers that came with the monitor picture is completely black after the restart although you can hear the windows is working properly(Vista ultimate 64).
When I install the ATI Catalysit driver (tried newest as well as the ones provided with the graphic card) hundreds of black horizontal lines apear throughout the screen. All components are brand new.
These things happen on both connections (DVI as well as VGA cable), even considered pluggin them both in, but i'm not sure what can happen if I do that.
I have assembled atleast 10 of  amd-ati based computers, and installed operating systems and everything that goes along, without any serious problems, that's why i'm puzzled even more with this one, so any advice, suggestion or hopefully solution is welcome!
    Guru:
  • 689 Answers
Id say this is a compatability issue before interference from other sources(Undefineable)
Posted on Sep 04, 2010
P191w
The Acer p191w uses the same power supply as the Viewsonic VX1962wm that your problem is a well known issues with that power supply. The filter capacitors go out and that causes the power supply to shut down within a few seconds. The monitor is easy to repair, you will just need to replace the bad capacitors on the power supply board. Here is a link to a repair guide for the Viewsonic VX1962wm and the information will be the same since the boards are the same in both units.
http://www.ccl-la.com/blog/index.php/viewsonic-vx1962wm-monitor-repair/
Dec 22, 2012 | Acer P191W 19" LCD Monitor
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
Sir i got a viewsonic lcd 19" model 1918 it
Let the unit cool down for 30 min., give proper ventilation because your processor have a heat sensor, once reached the peak temp the unit will automatically shuts off. Keep away all the obstruction from your vent.
Let me know if the symptom is still there...
Thanks for using fixya.
Feb 02, 2011 | ViewSonic VX910 19" LCD Monitor
I have a viewsonic monitor VX1962WM Model # VS11979 I turn it on and the screen go black in less then a min.
you probably have a bad invertor. you will need to open the case and replace the invertor
Oct 11, 2009 | ViewSonic VX1962wm LCD Monitor
I have a VX1962WM monitor. When I power up my PC I can see an image briefly then the screen goes black. When I power the monitor down and back up I again see an image briefly and then it is gone. I have...
That's right, the problem is related to inverter, but source of it - backlight lamps (if you see an image for fractions of seconds) or MOSFETs (if you see an image for few or more seconds). Image shows up, that means inverter starts, but then goes off because inverter controller turns into protection caused by something. Checking lamps is not that hard. Disconnect all cables coming from the screen and remove chassis with PCBs, so you will keep the display itself only. Next, at the edge where high-voltage wires are coming from, there you will see tiny philips screws, take them off. Then gently and very straight pull lamps assembly off the display, one and then another. If lamp is bad you shall observe contrast black ring or black dots near to the electrodes. Bad lamps must be replaced, you can buy them on ebay, for instance, just search CCFL 19". Or, if you don't care about total brightness, you can substitute faulty lamp with 27 pF 3kV capacitor, soldered across appropriate HV-connector on the inverter board - this will work also.
Sep 14, 2009 | ViewSonic VX1962wm LCD Monitor
1962wm screen has no display, flickers then goes b;acl
The backlight inverter has burned out.
Search eBay for LCD backlight inverter repair services.
Sep 05, 2009 | ViewSonic VX1962wm LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
ViewSonic VX1962wm LCD Monitor Logo
395 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
