Question about RCA HDLP50W151 50" Rear Projection HDTV
Start-up on RCA HDtvDLP M50WH72SYX12
I have a RCA M50WH72SYX12.For the last 2 days when you turn it on it goes thru a sequence of turning off and on with the green light flashing 5 times . Twice it didn't turn on at all. Now this afternoon it's on after going thru the same sequence. My manual says the bulb needs to be replaced. But I can't find a model # for the bulb. I tried the 800# on my paperwork and was told to leave the set on for 24 straight hours and then turn it off. Then she said to turn it back on to see if there was still a problem. She wouldn't give me a bulb # untill I try this. Isn't there a possible danger of heat buildup or the unit catching on fire? Is this some sort of reset?
  • hlblymrn Mar 08, 2009
    Ref:RCA Mdl# M50WH72SYX12 Delayed starting going thru sequence. Sorry, I havn't been on here in a while. We did get a new bulb. That wasn't the problem. Called 800# agin and asked for repair facility. Took it in and they said unit needs a Light Engine. Estimate of $1,076.70. Needless to say I went back and picked up my set and now am watching it. I'll let it keep going thru the sequence as long as it keeps working. Heck Thats about what I paid for it brand new. Needless I will be getting in touch with RCA. Unit is only 3 years old. Can anyone help. Have you ever heard of this.
I have the same problem, mines only 3 years old too! Hmm....
Posted on Oct 14, 2009
I can not fix it but I no the type of bulb Siries B Number 270414!
Posted on Mar 01, 2009
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Ignition turns over but car will not start...
sorry to hear your vehicle is down. check the fuel filter if so equipped, or could be fuel pump.
hope this helps. have a good day
Jan 29, 2010 | 1992 Isuzu Rodeo
Model #m50wh72syx12.... sound but no picture...
I have the same problem, TV is only 3 years old. Already replace bulb once and helped for a little while. The more I check, this sounds like a very common problem. Hmm...maybe a class action suit?
Sep 28, 2009 | RCA Televison & Video
20005 RCA 52" rear projection HDTVReady made a funny noise and it will not start again.
does the power indicator led flash 3 times when you press power then go out? I will also need the model number of your set.
Sep 09, 2008 | Televison & Video
I have an amana air command 90 furnace. the burner won't light.
This unit goes in steps, 1-- thru--4 Step 1, vent fan blower motor runs & prove thru the air tube, which closes a switch and tells the circuit board to go to step---2 Step 2 lights the glow plug and goes to step 3 automatically, Step 3, opens the gas valve and send in gas thru the long venturi tubes which lights from the glow plug and on the last tube, theres a rod that sticks into the flame, if no flame or not working properly, it will shut down the starting sequences and retry for 4-times and automaticaly lockout till unplug and start over. (whever step it stops at, then thats where your problem is!
Sep 06, 2008 | Amana Heating & Cooling
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA RT2250 consistant shutting off in Satalite mode.
Mine will always just turn off every minute or so after a hard shut down(ex: power outtage). I have to turn it back on and then hold the set button for a few seconds, then it stays on, until i turn it off manually, since the remote won't turn it off.
May 15, 2007 | RCA RT2250 System
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDLP50W151 50" Rear Projection HDTV Logo
510 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
