Question about Radio Shack Pro-94 Scanner
162.550 NOAA weather frequency
Can I hear the above said frequency on my PC through the internet connection
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I am not aware of any computer receiver ported for USB connection capable of 162.550 MHz; almost all are regular FM band. There are however amateur/ham radio equipment that could be interfaced with the PC that covers 136 to 174 Mhz.
If your requirement is to be able to monitor NOAA weather broadcasts, it might be simpler to use Internet Radio/audio streaming. NOAA addresses this particular issue here and here among others.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
Cobra CXT390 2-way radios find no noaa weather stations
You might have to manually enter the frequency for your area. NOAA uses 6+ channels, so you may have to google the frequency for your area.
Tom
Jul 11, 2013 | Cobra CXT390 Walkie Talkie Two Way Radios...
GRECOM PSR-200 DESKTOP SCANNING RECEIVER WHEN SCANNING WEATHER CHANEL KEEPS COMING IN.
NOAA weather broadcasts are continuous, therefore scanning is interrupted when your receiver locks on that frequency. You need to lock out all NOAA channels
Nov 17, 2012 | Grecom PSR-200 Desktop receiver, analog
Weather channel frequencies for Dover, Ol
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you with your request. You want the NOAA weather radio frequency channels for Dover, Oklahoma? Use the website below to obtain this information.
http://www.weather.gov/nwr/CntyCov/nwrOK.htm
Your county is located in the middle of the web page. Your county also has two frequency channels as well. So when deciding which one to use, consider the one that's nearest your area of residence. I suggest that you bookmark that website or put it in your favorites folder. Thank you for choosing FixYa as your one-stop spot for solutions to problems, questions, concerns or requests. I hope you stay safe this Tornado and Severe Weather Season. Remember to keep this radio on at all times and if you're noticing severe weather coming to your area, make sure to keep up-to-date with NOAA Weather Radio broadcasting. Have a good day, afternoon, evening, or night; whatever time of day you are viewing this solution post.
May 26, 2011 | Midland WR-100 Weather/RDS Radio
What is the Frequency or the western ky area?
all you have to do is go to www.noaa weather.com and you can download the whole states as there are about 6 different frequencies throughout western ky
Apr 15, 2011 | Midland WR-100 Weather/RDS Radio
How canifixmyscanner,it scansbut doesnt pick up program stations
You didn't provide the make or model of your scanner, or any real specifics on your problem, but your first step is to make sure that you've programmed active frequencies into it. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
For a functional check, you should first program and scan NOAA weather frequencies to verify whether or not the scanner is working properly. Many scanners have a WEATHER or WX band function that will let you check the NOAA broadcasts without any programming. If your scanner does not pick up the weather broadcasts you may have an antenna problem or an electronic problem that will require professional repair.
Bill B.
Listening in since the 60's
Jan 18, 2011 | Radio Communications
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
Scanner scans but will not pick up traffic
You didn't mention the scanner model, your location, or any specifics that could could help focus in on the problem, but here are some general guidelines for scanning:
1. Make sure that the scanner powers on from either AC power or batteries and that you have a proper antenna connected..
2. Check basic operation by turning the volume about halfway up and then rotating the SQUELCH control in both directions. You should hear a loud hissing noise. If you cannot hear anything while doing this the scanner is in need of professional repair.
3. Check scanner reception by programming a NOAA Weather frequency. 162.550MHz is the primary in most areas, but 162.400, 162.475, 162.425, 162.450, and 162.500 are other possibles). If you receive weather broadcasts on one of these frequencies, the scanner is working. If not, it probably needs professional repair.
4. If it passes the above tests, you need to make sure that you've programmed the right frequencies into the scanner. These will vary by location, and for a comprehensive database of active frequencies in your area, visit: www.RadioReference.com
I hope that this information helps. If not, please get back to us with specifics and we will do our best to get the scanner working for you.
Dec 13, 2009 | Uniden Radio Communications
Cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
Apr 10, 2009 | Uniden Nascar BC-92T Scanner
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-94 Scanner Logo
217 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
