Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
Relisys TL 766  Monitor Logo
Problem with the Relisys TL 766 Monitor
OSD function menu
By paddybae on Jul 29, 2007
The OSD function menu keeps randomly appearing and will not go, despite switching the monitor off and/or rebooting. I've tested all the connections but to no avail. When its on screen, the buttons are not working and it keeps scrolling through the menu. The monitor itself is about 2 years old. Any suggestions?
  1. menu keeps appearing of its own accord an wont go away i've tried everything turning mains power off an on agen also keeps going through the menu repeatedly an wont stop
  1. The OSD function menu keeps randomly appearing and will not go
  1. i have the same problem, very very frustrating, i have managed to make it transparent and put in the top right hand corner. the menu keeps jumping from one aspect to another. it moves in an anti clock wise direction. i have done all that was sugssted. turning off, taking mains out, holding in start button for 10 minutes. please help me work out this problem.
  1. This problem appeared about six months ago and fixed itself. Now it has reappeared but the time between it clearing the screen (using the on/off switch) and the OSD appearing has got shorter. It is now a matter of a few seconds instead of the several minutes it was previously. I have tried all the solutions that I have read on this and other sites but to no avail. Does anyone know what is causing this and how it can be stopped? Even if it means disabling the OSD.
  1. same problem here....screen menu cycling through menu, cant get rid of it.
Solution 1
posted 2 years ago
  • Rank: Apprentice
  • Rating: 70%, 14 Votes
ok i think i know how to get rid of it now, i did an ATX reset on it and it does go away HOWEVER as soon as you push the menu button again it comes back.
ATX Reset: unplug the main power lead then hold down the power button on the front of the monitor for about 10 seconds, plug the mains lead back in and then switch the monitor on.
Was this helpful?
Yes
No
2 people thought this was helpful
Add a comment
Solution 2
posted 2 years ago
  • Rank: Guide
  • Rating: 0%, 0 Votes
Ok it would seem that it has happened to me again and the ATX reset doesnt seem to work anymore however i have found a new fix, the on/off button on the right side of the monitor, switch it off then on very quickly, seems to do the trick :-)
Add a comment
Solution 3
posted 3 years ago
  • Rank: Apprentice
  • Rating: 59%, 2 Votes
I am having the same problem with a compaq fs7600. its driving me crazy
Was this helpful?
Yes
No
Add a comment
Solution 4
posted 2 years ago
  • Rank: Apprentice
  • Rating: 74%, 9 Votes
Here is a definite solution to all those having problems with OSD menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Have been advised company may be in liquidation and spares are almost impossible to find
Finnock.
Was this helpful?
Yes
No
1 person thought this was helpful
Add a comment
Solution 5
posted 2 years ago
  • Rank: Apprentice
  • Rating: 100%, 1 Votes
have had same problem but this worked for me, and (almost) permanently - I say almost 'cos when had to reinstall windows xp, it came back until fixed it (again). Incidentally the "switch the power 'rocker' button on the side on & off very fast" idea is only a temp stopgap - it works, but only for a varying time, and the interval gets shorter and shorter. This should tell you the problem is in the software, not the hardware. And doing this will eventually cause the power button to fail of course! Here's the fix -
in windows open start and run. Type in chkdsk /f and enter. A DOS box opens saying something like such and such will happen on restart; do you really want it? kinda thing. Press y and enter. (if you've got spybot or other registry change monitoring it will prompt along lines of do you accept change? Accept it - it's only a line of code in registry telling windows to do a job when next restarts. Restart. On restart windows will load then will go to a blue screen and do its stuff. Let it. Will then restart again and as will try to delete registry entry having done job spybot (or similar things) will again ask if you accept registry change. Accept. Enjoy. Oh, if didn't work, try same again - sometimes needs a couple of goes to do it but always works for me.
Was this helpful?
Yes
No
Add a comment
Solution 6
posted 1 year ago
  • Rank: Apprentice
Fixed problem osd.
With nolmal measurements, the diode zener 6,2 volts were alls ok. With electronic ohmeter it types them, the d2 had 30 megaohms, the others > 40 megaohms. Changed all four, resolved the problem.
Was this helpful?
Yes
No
Add a comment
Solution 7
posted 1 year ago
  • Rank: Apprentice
the solution is what finnock said it is easy enough to do your self.just take off the back of the monitor,and take out the pcb board that the menu wirers are conected to.they are just push fit.as finnock said no more stress.thanks finnock ron
Was this helpful?
Yes
No
Add a comment
Solution 8
posted 2 years ago
  • Rank: Apprentice
Bigger Al's solution on the '17" tft lcd " post works for me. I have used a hair clip and some masking tape to continually press one of the menu function buttons and this stops the menu appearing. Now what I would like to know is why it appears and what is the real cure?
Was this helpful?
Yes
No
Add a comment
Solve Your Relisys TL 766 (White) Monitor Problem Now!
Click here to get instant support from our best Experts
Please type the numbers below to complete your post:
Can't read it? Try a different one.
Type the numbers here:
Solve this problem
Bold
Italic
Underline
Insert List
Insert List
Video
Pictures
Insert Link
Links
Share your knowledge with the Fixya community today!
Popular Solutions for Relisys TL 766 (White) Monitor
Relisys vertical bars
Relisys rlt1720 LCD TV vertical/lines bars equally spread across the screen when switched on. As soon as TV is switched ...
LCD display failure
19" lcd monitor powers briefly displays then goes blank Dell E193FPc.LED indicator stays solid green .Changed out cords ...
all of a sudden there is no picture on my relisys
all of a sudden there is no picture on my relisys 15" tft monitor, sound and channel change work, please helpnessa, ...
connecting sky box to to non scart reysis tv,via...
this tv has no scart socket ,so i purchased an adapter kit. the tv works fine but only in monochrome. scart kit ...
How to use speakers
How can i use built-in speakers of my Relisys TL565 LCD instead of using external speakers ?
Unsolved Problems rss
Turquoise square with icons sitting in the middle
Turquoise square with icons sitting in the middle of screen! cannot exit it in any way
does this model have video input
Screen
Screen goes multi coloured flashing unable to see anything at all
unlock back of relysis monotor
Trying to remove back of 561 mon to check psu
Open Relysis monitor to repair
Solve this problem:
Bold
Italic
Underline
Video
Pictures
Insert Link
Links
What is this?
Get an Expert to Solve your Problem:
Top Monitor Experts
Rank: Guru
Rating: 92%, 2079 solutions
Rank: Guru
Rating: 91%, 6509 solutions
Rank: Guru
Rating: 90%, 6170 solutions
Get an Expert to Solve your Relisys TL 766 Monitor Problem
Get Immediate Assistance!
Let our Experts solve your problem!
More than 2 million solutions and counting...
