Question about Linksys Wireless-G WRT54G Router
Router Firewall Does the firewall on this router make it unnecessary to have another firewall on the computers that use it? Thanks, Charlie
  • Anonymous Jan 30, 2009
    my vwireless is speed slow
    Sergeant:
  • 219 Answers
Not entirely. Hardware firewalls (such as the one in your router) will block incoming connection attempts based on the port they're using, the protocol, and a number of other factors (varied between firewall brands). Some are designed to block only popular attacks (DoS, PoD, crackers on port 80, Telnet connect attempts, etc...) while others will block a larger variety of attacks.
Anyways, software firewalls will block almost all incoming Internet traffic (except for the ones defined in the exceptions) along with almost all outgoing Internet traffic. The only way I find this to be useful is if you're trying to keep some private information private, or if you use that computer to determine if some software is trying to phone home (web beacon, trojan, dialer, etc...).
I really don't see the need for Software firewalls unless you're a hard-core web-surfer and don't care what you click on. If you do like the extra security, perhaps one of the better software firewalls is made by ESET.
I prefer ESET to Symantec's Personal Firewall because Symantec's Firewall on one of my older systems was hijacked by a virus a few years back which allowed the virus unprecedented access to the root of my Operating System. The virus gutted the computer without any alerts from Norton CE or the Firewall.
Anyways, I hope this was the answer you were looking for. If not, please feel free to respond with more details on what you were truly asking. All the best. ;-)
Posted on Feb 03, 2009
SOURCE:
My internet connection became slower after i got xfinity internet and belking router.Can a cause of the problem be a conflict between belkins firewall and Mccafee firewall that i have for a long time.If it...
It could be a conflict.. but the main thing is there really is no reason to have a 3rd party firewall installed on windows, it has it's own firewall, then you have the firewall built in to the router, all mcafee's firewall is doing for you is taking up resources and potentially causing conflicts.
I would remove that firewall and see if that helps, if not, reset the router to factory defaults (there should be a reset button on the router) and configure it again, possible that it was not set up correctly or got corrupted somehow.
With the introduction of Windows 98 SE Service Pack 2, there is no reason to have another firewall installed.
Hope this helps
May 20, 2011 | Belkin (F5D5231-4) Router
How do i disable the firewall to enable updates? some updates won't install, error code seems to suggest a firewall may be stopping this, the router has a firewall and i think this may be causing the...
The router firewall should never be the cause of failing updates. If the update is detected and download, the installation can only fail because of local computer settings, not a router's firewall.
So your PC's firewall could (maybe) be the cause, but even that is not common.
What is the error message? And is this a Windows update or a specific program update?
Nov 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Firewall enabling on DI-524
Here is the link to the D-link DI-524 manual
its is in PDF format so please have adobe acrobat reader installed
I have the same exact router and this router has default firewall settings enabled. You must go under Advanced tab and then click firewall, in this area you can add your own firewall policy's.
Hope this helps
Please rate my solution, thanks
May 06, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I disable my DG834GT router firewall?
The router firewall only blocks connections coming from the internet.
Basically it only lets an outside IP connect to your network if you establish the connectoin FIRST.
The most common cause of not being able to see another PC on the LAN is not having the same workgroup name.
Go to Start > My Computer , right click > Properties > Computer name. Make sure all PCs have the same workgroup name.
Mar 05, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Disabling the firewall?
You have to know the required ports for music downloading in order for you to configure on your router.
Mar 01, 2009 | Westell Wirespeed ProLine 6100 Router...
Firewall
log into the router by typing 192.168.0.1 into your web browsers address bar. Then click the firewall tab and scroll down. At the bottom of the firewall screen you should see an "enable firewall" checkbox, just clear that checkbox click the save button at the very bottom. I personally wouldnt recommend completely disabling your firewall, if you really want to bypass the firewall with one particular computer, you should add that particular computers ip address to the "DMZ" list (De-Militarized Zone). And if you are just having difficulty with a particular program you can always set up port forwarding.
- Shawn
Feb 04, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Open a port for a certain program
hi mike,
this router has its own firewall, although i don't think its a good idea to turn off the firewall
google the port that limewire uses and then use portforwarding on the router.
you can start by turning off the firewall on the router to see if it works. if it does then perrhaps just allow limewire to passthrough your firewall at the router.
good luck
smeags
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Linksys wrt54g router
First of all, good questions.
To answer your first question, most linksys routers come with firewalls, but im not positive about this particular one.
Now for youur second one, installing a firewall ill work with linksys, Zonealarm is good, I also reccomend AVG.
Even if the router comes with a firewall, I would install one anyway, to be safe.
Hope this helps, and good luck :)
Dec 28, 2007 | Linksys Wireless-G WRT54G Router
Software Firewalls and Linksys Routers
You can never have too much security, however there are some firewalls that will not work with hardware firewalls, that includes the all Linksys Routers . Keeping this in mind, some software firewall will continue working after the router is installed. If it does, it shouldn't need to remove it, because it's an extra layer of security. However if there are difficulties using the Internet with the Software firewall after installing the router, try disableing it to see if internet is accessable. If the internet works after disabling the software firewall, then remove the firewall.
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys Wireless-G WRT54G Router Logo
130 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
