Question about Dell 2000FP 20.1" LCD Monitor
Monitor quit working
Just stopped working. changed cable and checked cord, still nothing
How to fix no signal cable on laptop
Select Fn+ F4 (check 2 monitors) for check the change monitor . if not fix press with out FN.
if not fix go to display resolution and select dual display and duplicate .also select video dislpy LCD or VGA out to Both.
use user manual to more info
Oct 07, 2015 | Samsung Computers & Internet
Non-Stop Auto Configure
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 09, 2014 | Acer X203H bd Monitor
15'' lcd energystar monitor problems
Try another monitor to verify the Graphics Card, if you have a graphics card, then another monitor cable. check for bent pins in the connectors, eliminate the hardware by changing each component/cable one by one. It may be the Graphics Card/Adapter is gone. Clean the inside of machine, overheating due to dust will cook components, GPU's get quite hot. Try some Electronic Contact cleaner spray on the Graphics Card connections, if applicable. Unplug before reseating the Graphics Card or cleaning, take precautions in ESD before handling a Component. If your Graphics is integrated, you can purchase a aftermarket PCIe x16 Graphics Card quite reasonably, : http://www.google.com/webhp?source=search_app#q=ati+amd+pcie+x16+graphics+card&hl=en&sa=X&tbs=vw:l,p_ord:p&tbm=shop&ei=ze05Uf25KJDO9ASIyYHYDw&ved=0CF8Quw0oAg&bav=on.2,or.r_qf.&bvm=bv.43287494,d.eWU&fp=bc2048b0dd90d6d4&biw=854&bih=580
Mar 06, 2013 | E-Machines T5048 (7136) PC Desktop
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
Princeton VL2018W stopped working. Getting popup "no signal- self diagnostics- check signal cable" When hook up to pc the initial screen showed computer specs than started the popup. Tried changes power...
1. Take this Monitor and attach it to another working computer to see if it works
2. If it works, it means the video card on your pc needs to be replaced
Mar 16, 2010 | Princeton Digital VL2018W Monitor
My monitor does not display any color other than blue.
Check monitor button to select proper colours or reset it to factory settings
Sep 08, 2009 | Gateway FPD1775W Monitor
Emachines computer problem
have you checked the cord and connection to the video card?also you could try resetting the bios.unplug the power cord on the pc.remove the batterie on the motherboard.power it back up.remove power cord again and replace batterie and restart pc.
Mar 04, 2009 | E-Machines eMachines Desktop PC
When I turned off my monitor last night, it was fine. When I turned it back on this afternoon, all of the colors were darkened and discolored. It looks like my contrast was change, but it wasn't, since no...
is this an lcd flat panel monitor or a crt? if it is a flat panel then you may be dealing with blown capacitors on the vga board inside. they can be replaced therby repairing the monitor. if it is a crt then just recycle it and buy a newer lcd monitor to replace this old one.
Jun 19, 2008 | Computers & Internet
Dim Monitor
I had the same problem, took it all apart and pushed on the socketed chip, it made a click noise and it works now. I also pushed on everything including the variable resistors. First time it's worked since it quit working!!
Nov 06, 2007 | Samsung SyncMaster 175V 17" LCD Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Dell 2000FP 20.1" LCD Monitor Logo
119 people viewed this question
Alun Cox
