Question about Microsoft Windows XP Home Edition
Cant IP Address
A couple of week ago i tried to go wireless. I got a router and set it all up. on network connections it says local area connection 6 limited or no connectivity. i tried to repair it but it cant renew my IP address.
The laptop connects fine to the internet wirelessly.
  • EricDaniels
    EricDaniels May 11, 2010
    What kind of router are you using and are you connecting to it through internet or through wireless like your laptop?
Press F11 when turning on your PC
Posted on Jan 31, 2009
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource :
Apr 26, 2012 | Computers & Internet
How come the address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern (i.e.,
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range through
• The default LAN IP address for the router is with a subnet mask of
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is, a printer may be given an IP address of to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be and the printer IP address If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    My computer cant find my router
    1. Make sure your network cable from the modem to the router is good and connected to the uplink port
    2. If connecting directly try other port
    3. Check local area connection properties
    4. Double click "local area connection"
    5. On the middle box find and highlight "Internet Protocol ( TCP/IP) and click "Properties" button
    6. Make sure "Obtain an IP Address automatically" and "Obtain DNS server address automatically" are the only ones checked and click "ok" button
    7. Make sure "ethernet card" is NOT disabled
    8. Update ethernet card driver if necessary.
    1. Turn wireless switch on
    2. Check wireless connection properties and that Internet Protocol TCP/IP configuration is similar to the above
    3. On wireless properties select "Wireless Network" tab and Add your SSID (wireless network name) if not there and if there Move "Up"
    4. Update wireless card driver
    1. Double check to see that "Automatic Configuration" DHCP is selected
    2. Double check to see if "DHCP"server is enabled
    3. Check wireless network mode and select correct mode
    4. Check wireless channels and adjust as necessary
    Jan 18, 2009 | Belkin (F5D7230-4) Router (587009)
    Wireless linksys wrt54gs router
    I have fixed this problem many times by entering just the gateway in the TCP/IP properties or all values as static e.g ip address, subnet mask and gateway as follows:-
    Limited Connectivity | wireless network
    Connect with an ethernet cable and find out the IP Address
    Also note the Subnet Mask, Gateway, and Primary and Alternate DNS values
    To get these :-
    1. Double click on Local Area Connection under Control Panel --> "Network Connections"
    2. Click "Support" --> Click "details"
    Enter these values for the wireless area connection like this :-
    1. Click "Start" -- > "Control Panel" --> "Network Connections"
    2. Right click on "Wireless Area Connection" --> select "Properties"
    3. Click on "TCP/IP" (in th middle box) -- > Click "Properties"
    4. Click "To use the following ip address"
    5. Enter the values you got from wired connection above
    6. If you get any duplicate warning messages ignore these
    This will resolve the issue, I have used it many times
    Jan 10, 2009 | Linksys Wireless-G WRT54GS Router...
    I can not connect to the local area connection.
    1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
    2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
    3. use IP address followed to your router address like if192.168.0.1 in router type or192.168.0.3 justcheck the next address IP in your network.
    4. after typing subnet IP will automatically set
    5. type the router IP address as your default gateway
    6. click OK to save your new settings
    hope this will help you
    Nov 26, 2008 | NetGear WGR614 Wireless Router
    We have Linksys G wireless router for our 2 home pc's and would like to get our laptop also connected - please help..
    - Let me know what is the configuration of your wireless?
    - If your configuration have no IP address included to access your Wireless connection?
    - You need to obtain the Network IP configuration for automatically connection the Wireless Point.
    - Let me know The Operating System of your Laptop?
    - The same Procedure if your Settings Wireless Connection or IP Address needed.
    - If you are using Windows XP Please Follow the Instruction.
    1. Select [START] =>
    2. SETTINGS=>
    4. Select your Wireless Connection if you have or your local Area Network then PROPERTIES.
    5. On GENERAL = Use Scroll down Under: This connection use the following items Select Internet Protocol {TCP/IP) then Click Properties.
    6. Select Obtain for automatically connection or add IP address if needed then apply.
    Sep 23, 2008 | Linksys Wireless-G WRT54G Router
    I cant connect my wireless laptop tp my comp.
    Let me know the settings of your Router if needed IP address?
    Yes - add your IP address into Network Connection.
    No - obtained the setting in your Network Connection.
    How to Add or Obtained the setting s of your IP address:
    - goto Control Panel
    - Double Click Network Connection
    - Rigth Click then Properties the Local Area Connection
    - Select Internet Protocol (TCP/IP) and select Properties
    - Under General Tab they have choices to add or obtained settings.
    Sep 20, 2008 | Linksys Wireless-G WRT54G Router
    Microsoft Windows XP Home Edition Logo
    78 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
