Question about Navman iCN 330 GPS Receiver
Screen is stuck
Message says application error ;error setting timer No more timers available
  • 3 Answers
Did you try to remove the chip yet?, sometimes that helps, and re boots the system?
Failing that, try to remove the battery, to enable the unit to completely power-down. Then refit, and try again.
There is a reset function, but i am assuming you are unable to access that if the screen is frozen.
I have listed how to remove the battery on another post on here.
Good Luck
Posted on Mar 05, 2009
Problems recording on LG RHT49H HDD
There may be plenty of space in the HDD but you can only set a certain number of timers. Delete a less important timer setting to make room.
May 05, 2014 | Televison & Video
Timer instructions
Well, you have kept it secret what make and model, but normally you would just keep pressing the Timer Set button to cycle it through the available times, until it got to zero or off.
Jan 07, 2014 | Hardware & Accessories
My et103c will not manually or electronically turn off my pool pump.
Copy following link to identify timer and download manual:
Unknown if this is new installation, or old installation that stopped working.
Check battery. The timer requires a battery. Located below the buttons.
ET103C digital electronic timer is discontinued but some folks still sell on ebay... selling possibly used timer. Timer has 1 year limited warranty from date of manufacture.
Timer has error code messages... if you receive no error code, then battery could be problem.
Line noise can cause timer not to function, such as fluorescent lights on same circuit etc.
ET103C clock mechanism is 120Volt 60 Hz. If pump and circuit are 208-240Volt, or 277V etc then this timer is not best choice unless neutral wire is available..
Add a comment and describe situation in more detail.
May 02, 2013 | Intermatic & Indoor/Outdoor Rain Tight...
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 26, 2013 | Oxo Hardware & Accessories
Error code 041
Our receivers can only hold a certain number of timers before some have to be deleted. To fix this message, on most receivers, press the DVR button three times to access "Daily Schedule". From there select 'Timers' then 'Edit Timers'. Once they have been deleted, more can be setup!
If you have any questions, or need further assistance, let me know!
Tommy Faust
DISH Social Media Representative
Sep 30, 2012 | DISH Network Televison & Video
Sga federal timer
Question is incomplete.
add a comment and identify what product type you have, and what voltage and application product is used for.
Also include what you are wanting to know, for possible solution, if available.
Federal Signal does not show a timer:
Do you need a timer for one of the federal signal products?
Sep 27, 2012 | Hardware & Accessories
The sleep timer is stuck on how do i get it to shut off
Canceling the Sleep Timer:
Press SLEEP to display the on-screen message.
2. Press SLEEP repeatedly until OFF is displayed.
Note: After 5 seconds of inactivity, the message box disappears
Mar 08, 2011 | Mitsubishi WS-65513 65" Rear Projection...
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual...
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
Jan 21, 2011 | DISH Network DVR 510 DTV Receiver /...
Prepare New Y Cart is the error message. I see it
The copier is almost out of yellow (Y) toner so it is telling you to make sure you have a spare one available for when it does run out. Get it prepared/ordered. It will eventually tell you that it is time to replace the yellow toner.
May 13, 2009 | Canon Office Equipment & Supplies
Navman iCN 330 GPS Receiver Logo
91 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
