Question about JVC HD-56G886 56" Rear Projection HDTV
Dark picture on jvc hd-55g466
Picture is dark and getting darker on jvc hd-55g466 tv. Tried adjusting but has no affect.
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Posted on Mar 23, 2007
SOURCE: Tv problem jvc hd56g786
your lamp bulb is probably finished so get a new lamp bulb they are easy to replace just look for a small panel on the side of you tv all you need is a flat head screw driver to open the panel and you should be able to pull out the lamp bulb
Posted on Nov 04, 2007
Mark_Webber
  • 472 Answers
SOURCE: Dark Screen
The lamps in these normally last about 3000 hours (if your really lucky). The bulb will start to loose it brightness as a matter of due course at about the halfway mark. It maybe that you are running the unit in the non economy mode that they are fading faster then normal.
The sets have a reputation for not being good with lamps though.
Have a look at the lamp though, make sure it has been off for at least an hour to let it properly cool and check for dust that has settled on it. Also if you wipe the lamp, make sure it is with a dry cloth, or allow plenty of time for any moisture to completly dry before turning it on if you use a damp cloth.
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: my JVC 56G787 is dark and bright is turned all the way up
replace the bulb and clean the inside mirror and screen. Use a microfiber cloth to clean both and vacuum any dust from inside unit. made me mad as well
Posted on Nov 25, 2009
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
Our tv has been getting darker and darker - we've tried to adjust brightness in menu and have it set to far right but its still too dark. Is there another adjustment to brighten the picture other than...
In many many cases this is an indication of a failing picture tube. The gun assembly in the neck of the picture tube is shorting. There is a fix, but this is surely last resort and the final cure may not provide a fix. Picture tube rejuvenation is not always successful. I would certainly opt for a new TV. Thanks for asking, and show a few hands of support!
Mar 13, 2011 | JVC AV-27530 27" TV
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
JVC HD-56G886 56" Rear Projection HDTV Logo
220 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
