Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Changing hose attatchment
How do you change the hose on he dc15, do you have to take the head off to replace it. My hgose split and although i now have a spare i cannot see where to replace it
  • 40 Answers
Http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
I am hoping that this link may help you with changing the hose.
Posted on Sep 28, 2010
How to replace dyson part 909545-06 on a doc-15?
Hi there, it's Jack at Dyson.
To remove DC15's hose and U-bend assembly, rotate the base of hose downwards until it clicks, then twist away from the machine. The new hose will then attach following the same method in reverse.
I hope this helps, but if you'd like our experts to talk you through it you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 20, 2014 | Dyson DC15 Vacuum Cleaner Internal Hose
Change the Hepa filter on Dyson dc15
Now for a proper answer haha,
Remove the bin and underneath you will find a large disc (filter holder) that the bin in sits on. This needs to be removed. Its not as easy as it should be either.
Lay the machine flat on a table and stand behind the filter and pull the two top tab points with some firmly place fingers. Once these tabs release the last bottom tab can be gently flipped off with a flat blade screwdriver from the back (behind the wand hose).
I like to peel out the old filter and clean it up with a razor blade. Once this is done you can fit a lower cost DC14 filter in and save some money. No peeling needed if you buy a DC15 filter for big bucks.
Good luck.
May 06, 2012 | Dyson DC15 All Floors - The Ball Bagless...
The hose does not work
Hi Colleen,
I'm sorry to hear you're having difficulties with your DC15. If the cleaner picks up as normal through the cleaner head but not through the hose, it sounds as if you have a blockage somewhere in the hose or wand. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=832&product=DC15-SY-STD
This should resolve the issue, but if you need any further help, please call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 22, 2011 | Dyson DC15 All Floors - The Ball Bagless...
The brush does not work on my dc15 animal, there is great suction but after about 20 seconds it sounds like something has got blocked in it although nothing is clogged, filters and hoses have all been...
Sorry to hear you're having a problem with your DC15. You might find it helpful to visit the Support section of our website and follow these simple steps:
http://www.dyson.co.uk/support/help.asp?article=903&product=DC15-ANIMAL
You should find this resolves the issue. However, if you're still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
May 26, 2011 | Dyson DC15 All Floors - The Ball Bagless...
I am experiencing some (not complete) loss of sunction when I use the hose
Possibilities:
Dirty filter, needs cleaned or replaced.
Partially clogged hose, needs cleared. Detach hose from tank and drop marble down the end of the hose. It should roll through the hose and power head to the floor.
Partial clog in the power head between where hose attaches and the brush. Detach hose from power head and drop marble into opening. If the marble doesn't roll through, there's a clog that needs removed. You may need to disassemble the power head to do so.
Leaky hose, needs replaced.
Clog between back of tank and filter. This is where the hose attaches to the tank. Remove clog.
Clogged filter at bottom of tank, needs cleaned. Remove tank. There's a screen at the bottom of the tank/vacuum. Simply remove/clean anything that may be covering/clogging any of the holes.
Dec 18, 2010 | Dyson DC15 All Floors - The Ball Bagless...
The hose on the DC15 vacuum serial # 030605VS is clogged and must be replaced as I accidentally vacuumed a bag of needles and the hose has pin holes besides, I cannot get it out. Is there a place I can...
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Check the above link to see if it helps. It shows you how to break down the DC15 to check for issues.
you can also try calling their helpline at 866-MyDyson for local authorized service centers or further help.
Aug 09, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
My Dyson DC15 has suddenly become very reluctant to turn left. This is only the case when it is switched on and irrespective of whether the roller brush is running or not. When the cleaner is switched off...
Hi its Darran at Dyson.
Although strange, I believe we have a solution. It sounds as though the cleaner head hose is blocked. When the machine is running the suction will be pulling against the bloskage causingt he hose to contract and prevent it from swivelling the left. When switched off there is no resistance in the cleaner head hose which is why it moves normally.
You simply need to check and clear the blockage from the cleaner head hose and this should resolve the problem.
Details on the blockage procedure can be found on our website at www.dyson.co.uk/support. From the Support section homepage, click on "My machine is not working", pick you machine and follow the diagnostics for my machine is not picking up correctly.
I hope that this information is useful to you.
Kind regards
Darran
Feb 17, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Changing the main hose on a Dyson DC15 Animal
Hi Bob.
If you look carefully where hose & elbow jount enter machine you will see a slot.
Rotate elbow so that lug on elbow aligns with slot & pull off.
http://dysonmanuals.llc.nu
Jan 12, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
94 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
