Question about Microwave Ovens
Microwave Quit Amana Microwave Model # AMC 2206BAB (less than 2 years old)suddenly started making a loud humming/grinding noise and won't heat.
  • Microwave Ovens Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number (AMC2206BAB) here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Posted on Jan 31, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My amana ACO1560AW microwave oven is not heating, all of a sudden and is making a loud hum sound. Worked fine earlier tonight but now it isn't.
Good day!
please open the cover and look for the thermal fuse/protector inside it is usually color white inside the silicon type rubber jsu replaced it and your problem solved..
thanks for using fixya..
Jun 30, 2011 | Amana Microwave Ovens
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Aug 18, 2009 | Whirlpool MH7140XF Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Sep 24, 2007 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
