Question about Tefal UltraGlide Easycord FV4256 Iron
Red light on
My tefal program 500 iron security light on all time my iron will not heat up
  • Anonymous Mar 16, 2014
    Not heating up. Red light flashes once then nothing
    President:
  • 1,214 Answers
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Posted on Jan 30, 2009
TEFAL STEAM GENERATOR GV8460 NO STEAM IRON HEATS UP
The water is heated by a metal plate that is bolted to the metal water tank, operating in pretty much the same way as a domestic kettle, the plate being the element. The plate is fixed in place by 8 or so nuts onto studs that form part of the water tank and heated by passing electrical current into this plate. Over time the nuts come loose and consequently the plate is not in full contact with the water tank. This results in insufficient heat transfer and a failure to consistently reach the required temperature to create steam. Ultimately you will need to remove the plastic base of the unit to access the plate and re-tighten the nuts. You will need a small 6 star bit with the centre punched out to remove the base as it is secured with security screws. These are readily available on ebay as they are the same as those used to secure number plates.
Apr 27, 2012 | Tefal Pro Express GV 8120 Iron
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
Jan 26, 2011 | Tefal Pro Express GV 8120 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
The auto stp security light is on and the iron does not heat up i have a tefal ultra glide iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
Sep 16, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 16, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
Jan 31, 2008 | Irons
Not getting hot
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Jan 10, 2008 | Irons
Tefal UltraGlide Easycord FV4256 Iron Logo
1,279 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
