Question about Mitsubishi WS48511 48" Rear Projection Television
Color convergence problem
Have a Mitsubishi rear projection tv, model # WS48511, that has a yellow half moon image at the top of the screen and has blue ghosting on picture and text. I have tried to adjust the convergence settings, the blue, green and red, and found the blue color, when in fine mode of adjustment, has the half moon image and unadjustable. I have reviewed postings on this site regarding color convergence problems and have found replacment of the convergence IC, STK392-110, would solve the problem. I would like a conformation or diagnosis procedure on the problem before purchasing.
Thanks,
Ed Rizzo
  • 4,234 Answers
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Posted on Jan 30, 2009
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
Horizontal and vertical lines themselves are off skew. can you adjust these convergence ines. everything else color ok
No,this tv 100% have convergence problems,it dead.Any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Mitsubishi WS48511 48" Rear Projection...
The top half of the screen is scrambling with wavy lines. Can this problem be fixed?
If you go into the customer menu and select convergence--instructions will appear on screen--select advanced and a grid of lines will appear.
If red or blue are skewed and will not adjust you have a convergence problem-If model ws48511 I have complete do it yourself instructions for this kind of fix.
YOU can post a photo here of what the picture looks like--I will attach one of a typical convergence problem--no two look the same but you will know if this is the problem you have.
SD TECH
Feb 17, 2010 | Mitsubishi WS48511 48" Rear Projection...
My rear projection Mitsubishi TV all of the sudden
No, this is a convergence circuit problem. The cost of this repair is about $450. This is something that you can't do on your own. Call an Authorised Service Dealer and get estimate or buy new one . If you buy a new TV buy an extended WARRANTY because they are not as reliable as the OLD TV's.
Good Luck, Big Irish.
Nov 21, 2009 | Televison & Video
Sony Kp65sw500
You have 2 IC's in the convergence circuit and possibly a micro fuse that needs to be replaced. Consult a local TV repair shop.
Nov 23, 2008 | Sony KP-57WS500 57" Rear Projection...
Colors off
I have the same problem, would like an answer.
Aug 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi ws48511 convergence problem
Your model uses one convergence IC its a STK392-110 you need to replace that IC. You can get a replacement at the following link with free instalation instructions with pictures so you can do the repaair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Mitsubishi WS48511 48" Rear Projection...
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Mitsubishi 50 in tv model # VS-5061
First of all check the circuit boards to see if ant CRT coolant has bee leaking on them. A strong flashlight will work best to spot it. It will usually appear on the front half of the boards nearest to the screen,. Mitsubishi has had some issue with CRT leakage. Also check for solder cracks around the Convergence amp ICs. Let me know what you discover, or if you need anything more.
Jan 31, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Mitsubishi WS48511 48" Rear Projection Television Logo
204 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
