Question about Sony Cyber-shot DSC-W100 Digital Camera
Cybershot dsc w120 - have to set the clock everytime I turn it on
Cybershot dsc w120 - I have to set the clock every time I turn the camera on before I can take pics. Tried Sony recommendations and charged the battery and waited 24 hours. No luck. Can anyone help with this problemI also have the same problem.! please if some one know how to fix this, send me the info to pompin7@hotmail.com thanks in advance!
  • 716 Answers
Select clock setting from settings on the home screen press circle on the control button. Select ^/v On The Control Panel Then Press Circle.Select Each Item With </> And Set The Numeric Value ^/V Then Press Circle. Select Ok Then Hit Circle. Once Complete The Camera Should Be Able To Power Off And On Without Loosing The Time. If It Still Doesn't Remember The Time And Or Date The Internal Memory Maybe Malfunctioning.
Posted on Jan 30, 2009
  • Michael Fisher
    Michael Fisher Jan 30, 2009
    Another Thing To Try Is Removing The Battery Then Installing It again.
    If The Unit Continues To Fail At Remembering The Date And Time Also Try
    Taking Out The Battery And Holding The On Off button for 30 seconds and
    putting the battery back in. You may also want to place a small folded
    piece of paper in between the door and the bottom of the battery to
    make sure the battery isnt loosing contact. If The problem still
    persists let me know and I will further assist you.
    Brigadier General:
  • 8,619 Answers
Hi!
Try setting the clock by selecting it from the menu shown
Clock Set: Sets the camera's internal clock
  • Rylee Smith
    Rylee Smith Jan 30, 2009
    If it still doesn't work then the problem is the battery isn't making a good enough contact. After you put the battery in, place a dime on top of it and shut the battery door - This should resolve your issue
    Sergeant:
  • 250 Answers
Set the dial to the black 'M' for manual, press the menu button and use the up/down arrows to navigate down to the time lapse function. Press the right arrow and note one minute appears in the screen and instructions on the bottom of screen that you press the menu button to start the time lapse. While the 1 minute is on the screen, you can press the up/down arrows to select 5,10,etc minute, I always use the one minute option, easier to delete than to re-shoot. From the time lapse / menu, the screen explains to press the shutter to start the time lapse. At this time, I make sure the focus is working, turn off the flash, (press flash button twice till small Icon is in upper left of screen) and make sure there is enough memory for the time needed. At one minute intervals, 24 hours will use 1440 pictures at one meg each, that is a gig and a half for the SF setting.
camera uses four AA batteries and has an the external battery Jack. I generally use the internal batteries only for keeping the clock set. Alkaline batteries have a longer shelf life that they have a much shorter camera photography life. This means they will last for many months to keep the clock set and only last minutes to take pictures. The rechargeable AA batteries will take twice as many pictures but will only last a month to keep the clock set.
    Brigadier General:
  • 3,614 Answers
try to reset the camera setting first, then after you already reset the unit set again the desired settings you want,.
let me know
    Sergeant:
  • 378 Answers
Set it as default.and confirm it after u set.and press ok.
  • Sony Master
  • 19,396 Answers
The internal cmos battery is faulty and need to be replaced, call back factory and ask how to get the camera repaired.
  • Ginko
    Ginko Jan 30, 2009
    Go to date and time and set the menu off:
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony cybershot dsc-w120 lens goes crazy whenever I turn it on and tells me to turn it off.
The camera should go off automatically when faulty. attempt to explore teh functions on the camera is discover the unique experience beyond power shut down requests. When powered on, capture a snap shot immediately or else the camera takes charge to poweroff to save batteries. Also, attempt to power charge since the insufficeient battery does not allow the camera to stay on long.
Jan 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony camera wont take pictures
It is problem of lens mechanism that does not send initialize signal to system control chip and camera tries 3 times for that then give up so that error message comes in result.
Replace lens assembly to fix the problem.
Local camera repair shop will help you to replace it.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
I can't use macro on my sony cybershot digicam
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
Aug 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Clock setting
If you set current time in clock set, it will not asked you again. I think you just cancel it when clock set display appears.
Apr 05, 2009 | Sony Cybershot DSC-H3 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
57 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
