Question about Canon imageRUNNER C3220 Color Copier
ERROR CODE What does the following error code designate: E000020-01b0 It tells me to turn the machine off and on to clear the code or contact technical support.
  • 168 Answers
I think the 1st drum from right to left is the yellow you need a new drum
Posted on Jan 30, 2009
Pls . help me experts , i have kyocera km3050 copier but the lcd touchscreen is not responding but days past when it still responding its getting hard to respond. please help me with this experts
A hard reset can clear minor error codes. A lot of times you do not really need to call for your support contractor. Sometimes errors stop the function of a machine, but the machine could still function properly with a hard reset. Perhaps there is a better description than hard reset, as "reset disable function" is a little bit confusing and not a phrase you were likely look for.
Contact your service provider before following these instructions.
Use at your own risk. Perhaps there is a possibility of causing damage. Again, contact your provider.
From our copier service company:
This reset is used for two purposes:
1) reset any data that may be "hung up" in the hard drive.
2) reset an error code and attempt to continue use. (If the error recurs, then you should escalate to whomever supports the copier.
Hard Reset Procedure:
Press Status button
Enter 10871087 - You are now in Maintenance Mode
Enter 906 (do not enter any other numbers!)
Press Start
Press Execute
Press Start
Copier tells you to turn it off/on
Turn off power by switch on right side of copier (hard power off)
Turn on power by switch on right
I have seen to use code 163 instead of 906. I don't know what this does. Again, consult experts before using this code or any others.
Feb 03, 2015 | Kyocera Mita KM3050 Black Toner Cartridge...
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
What is error code sc542
I found some information on this error at
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hi there
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 26, 2010 | Canon imageRUNNER 5000 Copier
The copier shuts down when trying to print
Look for the error code, that would lead you to the problem area, most likely the fuser assy. needs to be replaced. Do this, Press;
press 2 and 8 (together),
You should now be in Service mode, if not hit CLEAR twice then repeat the steps above.
press COPIER,
press ERR
the one listed at the top is the error code.(write it down)
You can try clearing the code then reboothing the machine with the right side switch and it might work.
This is how you clear the code, follow all the steps above except the last one (ERR) instead select FUNCTION above then CLEAR then ERR. Turn the machine off then back on again.
If that does not help and you are still having the same problem, you could either call Canon with a service call, call a local technician or get yourself a service manual and with the error code you wrote down above try looking it up or contact us again with the error code. Good luck.
Dec 18, 2009 | Canon imageRUNNER C3220 Color Copier
Image runner 3300 error code
it is a fuser film unit problem,thermistor is a poor contact (or) fixing heater is a problem.
do the following
press additionel function* button at once & press 2&8 buttons at a time and again press additonel function* button.
turn off the machine & on its again.
all the best.
Aug 09, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
E000014-0000 ir 3300 canon machine solution
May 03, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
Canon imageRUNNER C3220 Color Copier Logo
331 people viewed this question
old marine
old marine
