Question about HP iPAQ hw6515 Pocket PC
IPAQ hw6515 reboots by itself
My Ipaq hw6515 reboots or turns itself off every so often.It tends to occur when i'm using my GPS or when accessing my excel application intermittently. This seems to happen even when the battery power is 75%. It is occuring at a more frequent interval. The problem gets fixed (temporarily) when I sync using the docking station.
  • Anonymous Jan 05, 2008
    I have the exact problem when using GPS
  • jiggy_4urs Dec 10, 2008
    HP Ipaq hw6515 get switched off or restart automatically, when it is in pocket or at charging anytime....
I had same problem.
Culprint was in the back cover.
Above SIM holder is a hidden switch what will connect the backup battery when the main battery is removed.
Small hook (high up) in the cover will trigger the switch. When cover get loose the switch will change it's position.
I put small piece of shrinking tube in it what will extend it 0.5 mm. That did the trick. No more unscheduled reboots.
Posted on Jan 20, 2008
SUPERB,SOLVED My HEADACHE..
Posted on Dec 02, 2008
  • 4 Answers
There is a solution - jam paper in the top right hole and force the dreaded microswitch fully closed. This lets the Ipaq think the rear panel is on and it can fire up.
Full instructions for Ipaq 6515 fix here :
http://www.123datarecovery.co.uk/fix_ipaq_6515_6915.htm
Posted on Feb 14, 2008
This seems to be a common issue with the 6515 (there is a dedicated forum about it on the Cingular/ATT support forum website). there doesn't seem to be any particular solution. more a faulty design.
Posted on Aug 17, 2007
Hi, Try cleaning the contacts of the battery.
Posted on Aug 09, 2007
SOURCE:
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
Ipaq 6515 does not locate a gps signal
most probably your Gps module had developed problem.
Jan 03, 2009 | HP iPAQ hw6515 Pocket PC
Cannot receive send mms hp ipqq hw6515
Get the correct settings from your service provider, though most have an automatic service for this. Go start - settings - phone - network tab. and enter the settings
Dec 07, 2008 | HP iPAQ hw6515 Pocket PC
Gps wont start
The ipaq requires a GPRS connection to download and refresh its GPS files every 2 days. Check the GPS symbol at the bottom right corner of the screen. It has to be blue. If it is grey, the GPS files need to be refreshed. Hp recommends MapAsia and it works, though the landmarks are not correct. The roads are ok. I do not know about diginav.
Oct 24, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq 6515 gps issues
Hello, You may need to go get the update to 5.21 .. heres the link .. http://www.tomtom.com/support/category.php?ID=3&Language=4&FID=3370 Install it and that will help Bob
Jun 10, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq with GPS reciver
I think you should contact the company that makes the GPS and ask them if their software (drivers) will work with the Pocket PC you have and the operating system it runs.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
GPS...
Do you have sufficient memory on your iPAQ? Check your memory settings, also check running programs tab, maybe you have too many programs still running in the background causing the latency. Try a soft reset (stops all running programs in the background) or end task on them, then see if it still lags.
Hw6515 series and GPS
When connected with Activesync you can use your Internet connection on the PC. In the Activesync Window: Options/Rules/Pass Through - Connection: The Internet Then leave the PDA in the cradle and access the Internet on the PDA, works automatically ever after.
HP iPAQ HW6515 and SIM Card
There is a SIM manager , you can go there to download all your SIM contact to Ipaq address book.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
GPS Com Port Settings
Maybe you can try on com port 7 with baud rate 57600.
HP iPAQ hw6515 Pocket PC Logo
419 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
