Question about Microsoft Wireless Optical Notebook Mouse 4000
HOW TO SYNC TO MY COMPUTER
TOSHIBA SATELLITE
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
Jul 12, 2011 | Apple iPad 32 GB WiFi Tablet PC
Toshiba a60-155. keep getting press f1 setup screen. have to enter date. keys 1 and 2 don't seem to work. can I bypass this page
Don't think you can bypass this thing because the RTC (Real Time Clock) battery is, most likely, dead. But if you can replace the just the keyboard, then you'll still have a working computer. I'd leave the RTC battery alone and use software (such as Atomic Clock Sync) to set the date and time automatically every time the computer boots into Windows.
Jul 08, 2011 | Toshiba Satellite A60 Notebook
Can someone tell me the steps to sync the music from my ipod to my computer.
Download iTunes and follow the installation setup prompts. open the itunes application after install and the ipod will sync automatically. when sync is complete , be sure to push the eject button located at the middle left portion of the screen.
Dec 24, 2010 | Toshiba Satellite P105-S6197 Laptop
Change RAM in Toshiba Satellite A75 notebook
The Toshiba Satellite A75 came with either 256megs or 512megs of NON-REMOVABLE RAM. You will be able to insert a 256meg, 512meg or 1024meg stick of RAM in the slot. There will only be ONE slot to put the memory into. The only other socket on that computer will be for a wi-fi card but you would not be able to stick memory into that slot. The type of memory you will need is DDR333, PC2700, 200 pin SODIMM, 2.5 volt sync.
Apr 05, 2009 | Toshiba Satellite A75-S209 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Microsoft Wireless Optical Notebook Mouse 4000 Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
