Question about Brother XL-5130 Mechanical Sewing Machine
Needle clamp won't attach to needle bar
I was sewing heavy material for a ferret bed and talking to my daughter when the needle jammed, came down on the needle clamp,bent the thread guide.When I tried to put the needle clamp back on it falls off.It looks like the needle hit the needle stop inside. I can see something metal inside,don't know for sure if it is suppose to be there or not.When I insert a needle into the needle clamp and tighten the screw(not attached to the sewing machine) the needle is secure. I just cannot get it to stay on the needle bar.Please help.
Diana
  • 6 more comments
  • Anonymous Feb 20, 2009
    Same problem. Help!
  • Anonymous Apr 22, 2009
    the same thing broke on mine while sewing heavy material.
  • gopbecky Apr 29, 2009
    same thing here...i need help!!!
  • gopbecky May 11, 2010
    what kind of allen wrench? it's too small for any that i have...
  • Anonymous Mar 16, 2014
    Do I need a needle screw pin in order to tighten the needle?
  • Anonymous Mar 25, 2014
    When I try to sew it seems that the needles goes in coorectly and then when I start sewing the needle gets bent. Please help!
  • Anonymous Mar 31, 2014
    I need a replacement screw for the needle clamp
    What where size
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
How do I unlock it?
Normally when you have a jam with material the machine with lock up to prevent further damage. Once the jam is removed "completely" the machine will unlock on its own. But, on occasions it will not. Unplug the machine from the power & any hardware you have attached to it such as a computer. Allow the machine to "rest" for several hours. This allows the lock up to clear from the memory & the machine should preform when you return it to the power. Also remove the bed plates around the needle area & check carefully for leftover material, thread, dust, bent parts & replace the needle. Good luck.
May 28, 2015 | Baby Lock Esante
Machine won't feed material. I have to pull while sewing.
First of all stop pulling that will only bend your needle and cause further problems.
Check to make sure your feed dogs are engaged. There should be a switch somewhere around the sewing area front or back or perhaps under a flat bed attachment.
Oct 28, 2012 | Singer 4423 Sewing Machine
I HAVE A EURO SEWING MACHINE MODEL 373 IT WILL NOT SEW A STITCH
try these suggestions
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top & bobbin
make sure the bobbin is not warped
make sure the bobbin is wound correctly & inserted correctly
in the bobbin case
if none of these suggestions help,, then you might think about having
the machine checked to see if there is something wrong inside the
machine
Jun 08, 2012 | Euro-Pro 373 Mechanical Sewing Machine
Kenmore 385-16231 sewing machine. we are having problems with it breaking needles while sewing, we have never oiled this machine could this cause the needle breaking problem?
some sewing machines are self oiling some are not, instruction manual should tell,, when a sewing machine breaks needles it very possible that the machine is out of time & only a sewing machine repair shop has the tools to time the machine
Jan 24, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
How to replace the needle bar
There are only a few times when you need to change the needle on a sewing machine. One time is when the needle gets dull and it becomes difficult for the needle to pierce the material. Another time would be when, for whatever reason, the needle breaks. A third time would be when you change from sewing one weight of material to another. Whatever the reasons, changing a sewing machine needle takes only a few minutes to do.
these are the steps....
1.
  • Move the power foot control away to prevent accidently pressing it while changing the needle. Turn the hand wheel that is located on the upper right side of the sewing machine. Watch the needle while you are turning the wheel and stop when the needle is as high as it can go. If the thread is still inserted into the needle, pull it out.
  • 2
    Find the small clamp that holds the needle in place. It is located on the side of the needle bar. Grasp the clamp and turn it to loosen the needle. You don't want to remove the clamp entirely, just loosen it enough for the needle to be removed.
  • 3
    Remove the needle from the needle bar. If you are having difficulty maneuvering to get the needle out, open the needle plate. Be careful when removing a needle, especially if it is broken, to avoid sticking yourself. Set the needle aside, if you are switching out needles to use one for different weight material; otherwise, throw the old needle away.
  • 4
    Select the correct size needle. The different sizes are written on the colored end of the needle that fits into the sewing machine. Turn the needle so that the flat side is facing away from you. Slide it into the needle bar until it reaches as far as it can.
  • 5
    Hold the needle in place with one hand and grasp the needle clamp with the other hand. Tighten the needle clamp. Do not turn it too hard to avoid breaking it or stripping the threads on the clamp.
  • 6
    Clean any thread or fuss that is caught in the needle plate of bobbin case. Turn the hand wheel several times to make sure the needle is securely in place. Thread the needle and continue sewing.
  • Dec 02, 2011 | Sewing Machines
    Skipped stitches. Also, won't transition
    have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
    correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
    place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
    push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
    how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
    like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
    Sep 10, 2011 | Brother XL-2600
    Can't get the Lock Cutter Attachment to work. The right hand cut fabric won't feed through the fabric just won't go through and get cut and over sewn
    tally_girl_35.jpg have you got the little silver arm with a gap in it (see photo above mounted over the needle bar? This is essential as the movement of the needle bar going up and down is driving the blades in this attachment.
    The walking foot attachment for sewing machines works the same way, you need to place the little arm over the needle bar to make this aftermarket accessory work as its not driven by the sewing machine motor, purely by the movement of the needle bar.
    Saying that, I would be suprised if this attachment cut heavy weight fabric or several layers well, like many things made to imitate a purpose built machine (serger) there is no substitute for the real thing. It might be fine to just trim the fabric loose threads off a fabric edge but also you would need to watch that the trimmed bits are going somewhere and not getting into the seam or your machine. On a serger, the blades are working right beside a vertical drop off with a waste tray below and there is a lot of lint and fibres trimmed which quickly builds up. With this attachment, you'd have to manually ensure that the trimmed fibres are swept out of the way.
    I hope this helps you to get it working though - 4 thumbs up if so. :-)
    Jun 22, 2011 | Singer Inspiration 4206
    I have a stitching issue. I have a Consew 205rb and I just replaced the needle bar. I have everything setup to work and it grabs the bobbin thread everytime the needle goes down and comes back up but when...
    Once you replace the needle bar you have to retime the machine, why did you have to replace the needle bar? email me with your make and I will attach timing instructions.
    drivewithken@blueyonder.co.uk or you can keep adjusting the needle bar until the point of the hook is just above the eye of the needle.
    Apr 10, 2010 | Consew 205RB-1
    Brother XL-5130 Mechanical Sewing Machine Logo
    1,437 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
