Question about Microsoft Windows Server Standard 2003 for PC
How to find last login and time of any user - Microsoft Windows Server Standard 2003 for PC
    Problem Solver:
Call me at 00923326306950.
I Have a solid solution of your problem
Posted on Feb 01, 2009
I forgot my password and I can only log in as a guest
You can try the below given steps to reset administrator password using guest account (you must have write access to system32 file):
1. Navigate to location C:/windows/system32
2. Copy cmd.exe file to desktop and rename it to sethc.exe
3. Now copy this sethc.exe file and paste to system 32 (when windows asks for overwriting click yes).
4. Log out from guest account and at user login screen press shift key 5 times.
5. It will open command prompt with full administrator privileges.
6. Now type "NET USER ADMINISTRATOR xyz123" (where "xyz123" can be any password according to your choice) and press enter.
7. You will see "The Command completed successfully" and then exit the command prompt and login into administrator with your new password.
If you don't have write access to system32 file then you can use stellar phoenix password recovery software to reset administrator password.
Nov 12, 2012 | Computers & Internet
How To Find Windows 7 Administrator Password
Windows 7 administrator password is the password to any account that's setup to access administrator level functions in Windows 7.
There doesn't actually have to be an "Administrator" user account. What you need is the password to any account that can act as an administrator.
You will need to take a few times to get this password. You may need an administrator login password in Windows 7 if you're trying to run certain types of programs or access certain Windows 7 recovery tools.
Follow the steps below to efficiently find the administrator login password in Windows 7!
Difficulty: Average
Time Required: Finding the password to an admin user may take minutes up to hours depending on the situation
Here's step by step guide:
  1. Try leaving the password blank. If there is actually an Administrator account, the password may not exist at all!
    Just press Enter without typing anything when the logon asked for it.
  2. Enter the password to your account. Often times, depending on how Windows 7 was setup on your computer, the primary user account will also be an administrator user account.
  3. Try to remember administrator login password. As I mentioned in the last step, your account might be an administrator account, especially if you installed Windows 7 on your computer yourself.
    If that's true, but you've forgotten your password, you might be able to make really good guesses at what the administrator password might be.
  4. Have another user enter his or her credentials. If there are other users that have accounts on your Windows 7 computer, one of them may be setup with administrator access.
    If this is true, have the other user designate you as an administrator as well.
  5. Recover the administrator password using a Windows password recovery tool. You may be able to recover or reset an administrator password with one of these free tools.
    Note: Some password recovery tools on the list I have in connection with the above change and the ability to set user accounts in Windows 7 Administrator account. This can be useful if you know the password, but it is not an administrator account.
  6. Perform a clean install of Windows 7. This is a last resort option. This type of installation will completely remove Windows 7 from your PC and install it again from scratch.
    If you're just curious about the administrator password, I would not recommend this resort. However, if you need an administrator password to access the operating system of diagnosis and this is your last effort to save the computer running a clean install will work.
    Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Looking for your administrator login password but you don't have Windows 7? See How to Find Windows Administrator Passwords for instructions tailored for other Windows operating systems.
on Jun 04, 2010 | Computers & Internet
When was the last time the SQL Server sa password changed?
With the rights that the sa login has by default in SQL Server, it is imperative to change this password on a regular basis whether it is monthly, quarterly or semi-annually. In addition, as DBAs move on to other opportunities, it is wise to change the sa password as well. Changing sa password should be a relatively easy process requiring little to no impact on the organization. Unfortunately, changing the sa password on a regular basis is not a common practice at most organizations, because the impacts of changing the password are unknown.
The first step in the process is to find out when the sa password was last changed. If this timeframe is unacceptable to your organization, then steps need to be taken to understand where the sa login is used and how the application can be modified to use another login.
SQL Server 2000 - sa password changes
In SQL Server 2000 a documented process does not exist to determine when the sa password was changed. The best means to determine if the sa password has changed is based on the value from the updatedate column in the master.dbo.syslogins table. This value seems to be the only possible column to determine if any property (default database, default language, etc.) for the sa login has changed. Since the sa properties do not change frequently, the value for this column should be a reasonable, but not an absolute indicator of when the sa password was last changed. Reference the code below to determine the value for the sa login's updatedate column.
USE Master
SELECT sid, [name], createdate, updatedate
FROM master.dbo.syslogins
WHERE [name] = 'sa'
GOSQL Server 2005 - sa password changes
Unfortunately, SQL Server 2005 suffers from the same self documenting issue as SQL Server 2000 as it pertains to the last time the sa password has changed. The modify_date of the sys.sql_logins catalog view can be used as an indicator of when the last property (default database, default language, etc.) for the login has changed. Just as is the case with SQL Server 2000, this value does not guarantee the date ime stamp of the password change, but rather any property change. Since the properties do not change frequently under normal circumstances this value can serve as a reasonable, but not an absolute indicator of when the sa password was last changed. If other properties have changed, the modify_date is not a true indicator and other research/documentation is needed to determine the last sa password change date.
USE Master
SELECT [name], sid, create_date, modify_date
FROM sys.sql_logins
WHERE [name] = 'sa'
GOTo address the risks of changing the sa password, stay tuned for the upcoming tips in the sa series from
Next Steps
  • If you are scratching your head as to the last time the sa password was changed, then it is worth taking a look at your key SQL Servers
  • If the last time the sa password has changed is unacceptable to you, then begin to work with your team on taking the necessary steps to changing the sa password
    • In addition, stay tuned for the upcoming sa series tips on how to determine who and what applications are using the sa user name and password
  • In order to prevent the sa password from becoming stale in the future, be sure to put processes in place to change the sa password on a regular basis
  • For additional information from check out the following:
    • The first tip in the sa series - When not to use the sa password
    • Stay tuned for the upcoming tips in the sa series:
      • Determine how to find out who and what applications are using the sa user name and password
      • Password management options for the sa login
on Apr 08, 2010 | Computers & Internet
I bougth a new computer but when i was givein my sister my old computer the advent 9415 i forgot the password i tryed a few old passwords but it didnt work now when the computer loads it comes up as user...
hi,try to press control/alt/delete when windows boot up. then the administrator account will appear.commonly the administrator user name is administrator
user name:administrator password:(commonly there's no administrator password,just press enter)
Sep 23, 2011 | Computers & Internet
It keep telling me "YOUR
I couldn't see if someone else has already posted a solution. This same error message happens to us all the time-usually after a power failure, or windows decides to reboot the computer...In any case it will be necessary to login to "user magnager"..Once in switch to the tab that says "login"...then where it says "application" use the pull down menu to "icverfiy for window"
Then select any user that is listed , then go to the bottom of the page and select "log off user"...Close the program and start Icverify again...should be good to go
Feb 11, 2011 | Ic Verify Payment Processing Software -...
I am unable to login due to maintenance ..but also my profile is unavailable...what can I do Rena
Site Maintenance message usually means that Facebook is making an improvement to the database and after the maintenance is over, you will be able to login to your account without any problem.
Usually, this maintenance process takes just a few hours and affects only few users at a time.
If the "maintenance error" lasts longer than 24 hours and you are still unable to login to your account, kindly report the issue to Facebook Support by clicking this link.
Hope this solves your problem. Thanks for using FixYa.
Aug 08, 2010 | Facebook Social Network
Can't remember login password
As soon as the pc starts up (before windows or anything has come up) start rapidly tapping f 8 and keep tapping it until you come to a menu. There will be options like:
Safe Mode
Normal Mode
Last Known Good Cofiguration
choose safe mode. A load of text will fill the screen. leave it (may be some time) until you get to a login screen. Click "administrator". From this account you can change any users passwords
Nov 14, 2008 | HP Computers & Internet
Cant sign in to
usually hotmail account last 30 days from last login if you have not logined in 30 daqys im afraid afraid the account gone, unless you can recover the user information when you login to it. then maybe you can recover.
goto lost user name section of hotmail they have instruction on how to recover
Jul 03, 2008 | Computers & Internet
How to track Login Information for user in system
what type of system do you have so that I can look it up.
Apr 23, 2008 | Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
308 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
