Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire side by side - fridge side temp too low
Since Hurricane Ike (power loss) my fridge side freezes no matter what temperature is selected. Select 0 - food freezes. Select factory setting - food freezes. Select 6 - food freezes. 24 hours waiting period or not.
  • Anonymous Mar 26, 2014
    it will only freeze no matter how it is set
  • 359 Answers
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
Freezing milk and water bottles on top shelve
Defective temperature sensor in the fridge section.
Aug 30, 2016 | Frigidaire Refrigerators
Refrigerator side freezing and cannot control temp.
099b99d4-9ea3-4dba-a2ca-6c92989fe8af.jpgLook and see if the air damper called a=> 5304482075 Temperature Control Thermostat is opening and closing after selecting a different temperature. This along with the termostat are what controls the fresh food section temperatures. I am here should you have questions, Thanks Sea Breeze
Apr 25, 2013 | Frigidaire Refrigerators
I have a double door fridge, at the bottom is the deep freeze and top the fridge, the fridge is not working at all no matter what temp i set it on, but the deepfreeze is working, what could be the...
If the deep freeze is working it only means that your problem is on the thermo switch on the the fridge section. Try to check the temperature setting panel if its possible open it and look for the thermo sensors that switches the temperature in the fridge.
Nov 08, 2010 | Bosch KGU66920 Side by Side Refrigerator
Refrigerator 1/2 temp will not get warmer than 28 degrees
try and replace the thermastat control.
turn both knobs to the off position and listen i the fridge for the cold air damper to close it is located top left side rear of the cabinet in the fridge if the door does not close then you may need to replace the damper
Apr 13, 2010 | Frigidaire FRS26R4A Side by Side...
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
No matter what temp setting I adjust my fridge to it freezes up within hours. I now have a giant freezer. Where do you think the problem lies. I want my fridge back. It is a Kevinator Impression Series...
In spite of keeping the temperature regulator 'Low' mode if it freezes up so fast, that means there is a problem in the freez pipe from where the cool air is coming into the freezer. Please check on that. Make sure, that u defrost it once in a week.
thanks,
saumya.
Jul 13, 2009 | Frigidaire FRT15G4B Top Freezer...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Jun 06, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
807 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
