Question about Visioneer OneTouch 9220 USB Color Scanner
The OneTouch buttons don't work
The buttons were working before I acquired a newer processor, but have not worked since I reinstalled the scanner on the new system (Windows XP Home)
    Problem Solver:
  • 26 Answers
Try cleaning the fiber optic strip and the mirror-like thing above it on the carriage. It is a pain to get at but might help.
Posted on Aug 30, 2010
Can't acquire image from scanner says: The
Sounds like the TWAIN software is not being seen by the scanner. There are some generic free TWAINs available on line. If that does not work, I would look to get the latest driver for the scanner and uninstall it completely then, reinstall the driver before reattaching the scanner to the PC.
Oct 22, 2013 | Canon D420 AllInOne Laser Printer
Help...my visioneer onetouch 5800 usb scanner came without an installation cd and I can't get the drivers I need to make my scanner work!
From this official link you can get the drivers for your scanner. Note that this scanner is not compatible with Windows 7.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | Visioneer OneTouch 5800 Flatbed Scanner
I cannot get the scanner buttons to work. Nothing is showing up on my system tray to control the scanner buttons. The scanner works fine with software control thru Paperport. I have reinstalled One...
This is usually a symptom of either the basic driver being installed (not the OneTouch 4 software), the destinations for the buttons not being set in the OneTouch 4 software correctly or the monitoring program not being active. (For the X7600, the OneTouch 4 software comes with PaperPort programmed as the default destination for the scan button. If that setting got changed, it could cause the problem.)
The drivers and software are available here: http://www.xeroxscanners.com/en/us/products/drivers.asp?PN=X7600 . Scroll down for the manuals. If you have the basic Xerox driver installed, uninstall it (remove the scanner from the Device list by right clicking on it and choosing uninstall) then disconnect the data cable. Finally restart the computer and then install the One Touch 4 software.
If you have the OneTouch 4 software installed, check if the program is set to run on startup.
Click Start > Run then type "msconfig" (without the quotes) in the Open box. Click OK. Choose the startup tab and look for the Xerox software. Make sure the box is checked. Click Apply after changing the settings and restart the computer.
Next, launch the program (Start > All Programs) and try to launch a scan from the One Touch button panel on the computer. Adjust the settings if needed in the Configuration section of the software (see the manual for screen shots).
I hope this helps.
Mar 29, 2011 | Xerox 7600 Flatbed Scanner
I have upgraded to Windows 7. Where can I get drivers for Visioneer One Touch 8920 Scanner?
You can't. This is an older model, "end of life" per Visioneer, and they never released drivers for any system later than XP. If the XP drivers don't work, you'll need to replace the scanner with a newer model.
Jan 17, 2011 | Visioneer OneTouch 8920 Flatbed Scanner
Driver for vsioneer OneTouch 8900 for Windows 7
First install your regular drivers for your scanner and then turn it off.
http://support.visioneer.com/products/9420/downloads_1.asp
Download drivers for your scanner from the page above, don't mind it is not the same model - it will work. Also it will work with One touch 8700 Visioneer windows 7 x64 with the drivers for 8900 and 9420.
Next, install the driver, and then open Windows Explorer i locate files at:
C:\Windows\twain_32\VizScan\8xxx. Copy them all to:
C:\Program Files\Visioneer\OneTouch 4.0\9420 Driver
Next step is to tell your computer exactly what driver to use by right clicking on My Computer in Windows Explorer, then Properties, and then Device Manager. Now, turn on your scanner and it will appear on the list. Right click on it and select Properties. There click "Browse my computer for driver software" and then "Let me pick from a list of device drivers on my computer" and browse to: C:\Program Files\Visioneer\OneTouch 4.0\9420 Driver. Select OT_9420.inf and install it. Now u can use your scanner on Win7 and enjoy! Don't mind the different name! ;)
All the best to ya all
Dec 18, 2010 | Visioneer OneTouch 8900 Flatbed Scanner
I am unable to scan in Onetouch 9220 after I unlock the button.
Look for the fiber strip along the bottom of the scanner inside the glass. Clean it and the mirror-like thing on the carriage above it. These things work together to encode and decode. Dirt drives them nuts.
May 24, 2010 | Visioneer OneTouch 9220 USB Color Scanner
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Software to makE ONETOUCH VISIONEER 5800 scanner work with WINDOWS VISTA
You can go to Visioneer.com and order the disk. It is free but the shipping is $9.99.
Aug 03, 2008 | Visioneer OneTouch 5800 Flatbed Scanner
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
66 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
