Question about Bernina 1008
Problem with bobbin thread!
The machine was given to me a couple of years ago. I paid a hundred pounds to get it fixed but still not comfortable with using it, Until a couple of days ago i had a really good run and very excited. But now the Bobbin thread keeps on knotting up and forcing the machine to stop.
I have tried cleaning and oiling the bobbin, to no avail.
I hope you can help me in this matter, Best RegardsĀ
Joshua Raffell
    Problem Solver:
  • 6 Answers
Take out the bobbin race thing (behind the bobbin case) clean the area up. Oil the race, just a drop. Check the bobbin case for thread under the tiny spring (use tweezers if you see any). Make sure it's a good bobbin and that it unwinds clockwise. Up top, check your thread path and make sure you thread while presser foot is UP. Spool should also reel off clockwise. It's gotta be something like that. I have several of these machines (old Berninas, that is!) and there's almost never a problem.
Posted on Jan 31, 2009
My top thread will not pick up the bobbin thread. It looks like the hook comes around too late to catch the loop of the top thread?
It sounds like your machine is out of time. Search for sewing machine timing or take it for service.
Oct 16, 2017 | Sewing Machines
My bobbin thread gets caught below I took plates off thread is tangled on a silver bar going left to right can we fix this?
try increasing the needle thread tension as the bobbin thread is not being pulled up and out of the way
Feb 14, 2017 | Sewing Machines
Riccar stretch 500fa Needle won't pick up thread from bobbin
Check to make sure you are using the correct needle for the machine, that it is a brand-new needle, and that is installed facing the correct direction. Other than that, it's quite possible the machine was knocked out of time and needs service.
Apr 07, 2017 | Sewing Machines
Kenmore 1774
My sewing expert (spouse) says you may have thread caught in the bobbin area. Remove all the thread from the top, they look inside, you may find the problem.
Be blessed.
Feb 01, 2014 | Kenmore Sewing Machines
Bobbin pops out and needle thread and bobbin thread bird nest
here's my suggestions
change the needle-make sure the needle is inserted correctly
into the needle holder & also turned the right way
make sure when sewing on the machine that the top thread does
not come off the thread take up lever
check the top thread tension it may be too tight,, usually 4 is good
or if the machine has automatic tension set it there
make sure it's the right needle for the machine & make sure it's the
right needle for the fabric & thread.
some thread is knotty ,,, make sure the thread is good quality
Sep 10, 2012 | Singer Inspiration 4210 Mechanical Sewing...
I haven't used my 7570 for a few years until a couple of days ago. When I tried to wind a new bobbin, the thread did not wind tightly, but made a big loose mess, with thread extending beyond the edges of...
If your machine has not been used for a few years, chances are the oils in the machine have drained from where they should be. It might be a good idea to get it serviced whether or not you solve the bobbin winding problem. One thing I would try is to run the machine with no thread for a bit - not flat out, but just to get the oil that is in it warmed and lubricating the moving parts. Stop if you hear strange noises that don't sound right. I have a 7550 which is basically the same as the 7570, but can't think of anything that might cause your winder to behave in this manner. It is after all a pretty simple procedure. It might be that the winder was on its way out anyway before you stopped using it a few years back, and the lay-off was the last straw. It probably would not be a really expensive repair and well worth it - these machines are fabulous!
Aug 05, 2010 | PfaFF Creative 7570
Where can i get my sewing machine fixed? i have a Necchi sewing machine, and it does not work. i bought it two years ago and it was working perfectly. i've tried everything it said in the manual, but it...
make sure you have it threaded right and picking up thread at bobbin
brfore sewing i have seen a lot of people put the thread the wrong way through the needle and it will have this problem
Dec 31, 2009 | Necchi Sewing Machines
Bernina 740 favorit timing
boscados 740 840 940 742
Jan 12, 2009 | Bernina Activa 130
Singer model 9134
i had the same problem
it was stored in a garage (lots of heat) and i had a plastic bobbin
tons of thread on the bobbin side
so i bought new ones (brother brand) same problem
my friend pointed out the brand of bobbin makes a difference
so what the hek a couple more dollors before i toss the machine
and it worked when i bought singer brand bobbins
the heat must have shrank my first ones (like a shrinky dink )
your mileage may very
Dec 29, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
130 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
