Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365.
Also you will need to open the ports on the router.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Click Here for more info
